PBM’s Battery Chargers - A complete choice to recharge LITHIUM
- 20 Mar 2025 ( #1222 )
The role of lithium-ion technology in intralogistics is becoming increasingly important: lithium-ion batteries are lightweight, have a long service life, are maintenance-free, extremely energy-efficient and have an impressive charging time. All major forklift truck manufacturers now offer models with a lithium-ion battery.
PBM has developed a full range of chargers for any Lithium application:
  • ON BOARD Charger IP65  799W, 1000W & 1400W
  • 1 phase charger 230VAC +/-10%   from 2KW to 6KW
  • 3 phase charger 400-480VAC +/-10%  from 6KW to 40KW
A three phase, high frequency Modular Charger, suitable for all lead-acid and lithium-ion  battery types.
Our new technology utilizes 6kW and 10kW modules, allowing scalability and flexibility, by connecting in parallel same module types. The modular charger can  reach up to 40kW power.
Discover it at LOGIMAT - Booth #10C61 in Hall 10.
Benefits of technology & design
  • Modularity and flexibility
  • High configurability and ease of customization to fit any combination of voltage, current and power requirements
  • High efficiency technology for optimal energy consumption and cost savings (efficiency up to 94%) integration of Power Factor Correction (PFC) to maintain a PF close to 1 under all operating conditions
  • High flexibility lead-acid standard / GEL & Lithium-ion curves
  • Optimized charging profiles for quality that extends battery life
  • Lithium battery ready (adding CAN BUS communication accessory)
  • Easy to use with four (4) LED charging status indicators and multifunctional LCD display for monitoring real time charging curves and charging parameters
  • Easy to install (wall mounting ready)
  • High energy saving cost & Easy maintenance
  • Serviceability
  • Available for Opportunity and Fast charging
  • Less modules in parallel connection, for high power
Click here for more info about Modular.
