Bolzoni Group at LogiMAT 2024 to present the new Home Appliance Telescopic Clamp
- 14 Mar 2024 ( #1170 )
5 min read
New Bolzoni Home Appliance Telescopic Clamp, model KT-CF, with both arms rigid.
Bolzoni Group is proud to announce its participation to LogiMAT 2024 at Stuttgart Trade Fair Centre, in Germany, 19-21 March, 2024, with two Stands: in Hall 10, booth F65 dedicated to forklift truck attachments and in Hall 7, booth A21, fully dedicated to scissor lift tables.
With special focus on paper and recycling, food & beverage and white goods handling industries, on booth F65 in Hall 10 we display a wide range of material handling solutions, including electric and hydraulic driven forklift attachments, a new fork range and several cutting-edge product innovations.
In addition, Bolzoni Group has the pleasure to unveil its latest innovation in white goods handling: the Home Appliance Telescopic clamp with chain pulling concept.
Thanks to its know-how on specific white goods handling procedures, Bolzoni Group enlarges its White Goods attachments range with the new Home Appliance Telescopic clamp, model KT-CF.
Bolzoni Home Appliance Telescopic Clamp - based on the Chain Drive System for complete arm synchronization – is suitable for the handling of home appliances and is specifically designed for the handling of pallet-less loads, e.g. washing machines in confined spaces, such as containers and road trucks.
The combination of a chain drive with a tubular arm guide system provides an extreme wide opening range of 380 to 2.380 mm (15" – 94"), with minimal chassis width.
Thanks to its technical features this clamp represents a benchmark in efficiency for warehouse and logistics operations: the optimum synchronism of the arm travel and a maximum of speed make it a state-of-the-art attachment in white good industries.
This is how we move it
Well protected cylinders actuate the inner arms, while the external arm set is powered by a chain drive. The intelligent arrangement of the drive components, such as the cylinders, chains and tubes, provides an optimum of visibility for a safe and efficient operation. The robust chassis construction consists of 4 chromed guide bars.
Bolzoni carton clamp KT-CF model arms are equipped with bolt-on steel panels coated with a vulcanized black striped rubber, easy to replace without the need to exchange the entire arms.
The main technical features of the KT-CF clamp are:
  • Capacity of 700 kg @ 350 mm (1,550 Lbs @ 13.8") load centre
  • Wide opening range of 380 to 2.380 mm (15" – 94"), with minimal chassis width, offering a high operational versatility
  • A minimized weight and lost load provide an optimum of forklift truck residual capacity
  • Benchmark in efficiency – the fast arm travel speed supports the handling efficiency
  • Full synchronization of arm movement with the BOLZONI Chain Drive System
  • The tubular arm guide system reduces the energy consumption
  • Optimum visibility in the operation, improving safety and efficiency
The chain drive combined with the tubular arm guide system provide an extreme wide opening range.
This and much more to set your business up for the future
Bolzoni Group is proud to announce its participation to the LogiMAT 2024, Stand 10F65 and Stand 7A21.
Within the exhibit on stand 10F65 you find our Intelligent Products of the easy-Connect range:
  • Automated Guided Vehicle (AGV) Fork Positioner
This electric driven fork positioner is part of the AGV attachments range. With all sensors and wiring already included in the supply, the attachment is ready to be fitted on the AGV and to run. Wide attachment range already available, both hydraulic and electric driven, with specific sensors controlled and managed directly by the AGV monitor.
  • Easy-FORK Vision Systems
Our range of intelligent forks: fitted with cameras, laser beams and led stripes to improve safety and productivity granting for better visibility from the driver seat.
Moreover, in this edition, Bolzoni Group presents its new enlarged high-capacity fork range.
With capacities up to 220 tons (484,880 Lbs), Bolzoni high-capacity forks are perfect to equip lift trucks, construction and agricultural material handling machines, to cope with heavy-duty material handling.
Other forklift truck attachments displayed are:
  • Multiple Pallet Handler – Green Footprint and Total Cost of Ownership
The MEYER 4/2 Pallet Handler, with its completely encapsulated MEYER Shaft Guide Concept for fork positioning and a permanent lubrication system for sideshifting function, provides exceptional maintenance intervals and allows extended operating times for an increased productivity.
  • Recycling Bale Clamp, with cylinders and valve protection
This SILVER LINE bale clamp is extremely robust and is perfectly matching the recycling industry requirements.
The prompt delivery, the competitive price and the 3 years warranty enable the customer to optimize the return on investments.
Stand 7A21: environmental sustainability and operational efficiency with Bolzoni Lift Tables
Bolzoni Green Line 1E-Rot lift table thanks to the manual circular turntable improves ergonomics of the operations.
At LogiMAT 2024, on our lift tables Stand 7A21, we exhibit a complete range of scissor lift tables, focused on environmental sustainability and ergonomics. Come to experience integrated solutions to improve safety and operation efficiency.
  • Green Line Manual Circular Turntable Lift Table
The 1E-Rot lift table provides 360-degree rotation of the load in both directions, making handling and assembling operations easier. The load is accessible without having to reach out or to walk around the table.
  • Green Line U-shaped lift table
With a very low closed height, this lift table doesn’t need a floor pit, offering flexibility in positioning and keeping installation cost to a minimum. The U-shaped platform allows to directly load pallets with a hand pallet truck without an access ramp.
  • 1A Lift Table fitted with safety options
This heavy-duty lift table is the best option in engineering and production processes such as wood, metal sheet, plastic material, and paper plants. The shown model includes safety options such as handrails, roll-off stop, bellow and more.
Visit Bolzoni Group at LogiMAT 2024, Hall 10 Stand F65, and discover our latest innovation and material handling solutions.
Don’t miss our scissor lift table range Stand A21 in Hall 7.
We look forward to welcoming you on our Stands!
For more information on our products visit our website https://en.bolzonigroup.com/, get in touch with Bolzoni Group, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
