Forklift truck maintenance: make it easy and safe with Bolzoni lift tables Scroll down for video
- 21 Dec 2023 ( #1159 )
5 min read
Bolzoni Group lift tables plant, in Podenzano, Italy.
When it comes to seasonal peaks, it is very important to prevent unexpected criticalities related to logistic management or forklifts and pallet trucks sudden breakdown, as this could slow and heavily affect the operation flow.
For this reason, companies having forklifts and pallet truck fleets in perfect condition prevent interruptions to the logistic flow, keep a high production efficiency, as well as preserving the fleet's value over time.
Bolzoni Group, within the wide range of lift table models and capacities for each handling operation, has designed a model specific for forklift truck maintenance.
The greater the simplicity with which these operations are carried out, the greater is the strategic advantage for the business logistics.
Working closely with companies in material handling industry, Bolzoni Group has designed a specific range of lift tables to match each specific requirement.
Lift tables are used as ergonomic working stations for lifting and lowering loads at required heights in safe conditions for the operator. Used in feeding of processing machinery (in wood, plastic, glass, steel, ceramic) the scissor lift tables are often used in conveyor and packaging systems.
The lift tables are often applied in airports, to load and unload pallets for aircraft, luggage, and even vehicles. The lift table can solve many logistics problems and be used as a loading bay.
Main components are the top platform, the lower frame, and the scissor system activated by one or more cylinders. Scissor lift tables have become a commonly used type of equipment in many different industries.
Lift tables are used as connection between different stages, and represent the best solution for manual load handling, in full observance of European standards with regards to functioning, cost saving, safety and health of operators during work.
Bolzoni lift table models 1A – LS: great efficiency in forklift truck maintenance
Lift tables improve ergonomics allowing operator to adjust the platform height, preventing strain and injuries.
When it comes to forklift truck dealers with rental truck fleets, vehicle maintenance is one of the basic tasks.
During the maintenance of forklift trucks, access is complex and often physically painful for the operators. This lift table model is specially designed to optimize the process of maintenance of forklifts and to provide an optimum ergonomic workstation to improve the working conditions for the operator. Therefore, it represents an investment to provide efficiency and productivity for the maintenance and assembly of forklift trucks.
The Bolzoni 1A-LS lift table, with capacity of 7000 kg, is specifically designed to optimize the maintenance process of forklifts and pallet trucks and to improve working conditions by ensuring an optimal ergonomic workstation.
For this purpose, the special U-shaped top makes it easy to carry out activities in the correct position. On the other hand, the lift table allows to lower and raise the truck to a certain height to let operators work in the most comfortable way, increasing efficiency and productivity.
Lift Table for Forklift Truck Maintenance 1A-LS
“One of the most appreciated features of this lift table model is the obstacle absence once lowered,” says Paolo Marenghi, Bolzoni SpA Italy Sales Manager. “This lift table optimizes space even in small workshops, keeping a high safety environment.”
Designed to guarantee maximum safety
With the flaps on the front side and safety wheels rear stop system, a Bolzoni lift table allows the operator to position the forklift and elevate the table in full safety. The rackwork lock system ensures safe stopping of the descent; in case of contact with obstructions the aluminium safety bar stops the descent of the platform.
Moreover, the table is equipped with a safety check valve to stop the lift table lowering in the unlikely event of a hose break.
Bolzoni vehicle lifts comply with the provisions of the Machinery Directive 2006/42/EC and are manufactured in accordance with UNI EN 1493:2010 safety standard requirements.
Bolzoni Group is one of the largest worldwide manufacturers of scissor lift tables
Bolzoni lift tables are manufactured in the Italian plant of Podenzano, in a dedicated area of 5000 sqm, and are guaranteed for 12 months after delivery, accompanied by the relative declarations of conformity according to European standards.
Thanks to high quality components, modern production techniques and accurate final tests, Bolzoni lift tables offer a superior quality and reliability and operator safety.
With a long experience of almost 75 years in the production of forklift truck attachments, forks and other lifting systems, Bolzoni Group can offer customized projects, adapting the necessary technical and installation characteristics depending on material handling specific requirements.
Bolzoni Green Line: the ecofriendly alternative
Green Line to keep the load at the right height in all kinds of industrial applications such as assembly lines.
Bolzoni promotes research and innovation to produce sustainable equipments. For a lower impact on the environment, Bolzoni lift tables are available, on request, with biodegradable hydraulic oil and are all equipped with high efficiency IE3 electric motors. Lifting platforms are painted with water-based, solvent-free non-toxic paint.
Bolzoni Spa is certified with the Environmental Certificate ISO 14001: 2015, since 2006.
Wide range of accessories to meet the safety requirements for lift tables
The wide range of Bolzoni lift tables and options represents the optimal solution to many vertical handling requirements. Thanks to our experience, we are able to suggest and provide customized solutions.
Bolzoni lift tables are designed to work in safety condition also with off centered and crossing load. A wide range of options such as manual bridge plate, safety handrails, goalpost, are available for specific requirements and to comply with safety standards.
For more information on lift tables get in touch with Emanuela Solari, the Bolzoni Group Lift Tables Specialist.
Visit the dedicated Lift Tables section on our web site and contact us, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
Muncie, IN, United States
