PhoeniX 2829-XS and 2821-S from HUBTEX: new electric multidirectional sideloaders for handling long goods
- 17 Aug 2023 ( #1141 )
Space-optimisation with narrow aisles
Narrow-aisle warehouses are masterpieces in space-saving. Yet the narrow aisles between the high racks still need to be navigated, placing particular requirements on handling long loads and calling on logistics operators to take specific safety precautions. Two new vehicle series designed for narrow aisles – the PhoeniX 2829-XS and 2921-S – guarantee both safety and compactness.
The new PhoeniX 2829-XS and 2921-S from HUBTEX were specifically designed for use in narrow-aisle warehouses.
Companies short on storage space often opt for a narrow-aisle warehouse, preferring to pack their products high to minimise aisle width. This means reducing the safety clearances between each side of the industrial truck and the rack from their usual 500 mm to a minimum of 100 mm. It also places greater demands on the materials handling equipment, requiring it to be strong, compact and manoeuvrable in order to transport and lift long loads along the narrow aisles. HUBTEX's new PhoeniX 2829-XS and 2821-S series have been developed specifically for use in narrow aisles.
“Lift truck drivers can manoeuvre safely while also lifting their customers’ specific loads without causing any damage because the vehicles are so compact and come equipped with integrated rack guidance systems such as mechanical, inductive or optical track guidance,” says Michael Röbig, Head of Product Management. “Space-saving sit-down or stand-up cabs also give lift truck drivers an unbeatable all-round view. At the same time, assistance systems such as the mobile personnel protection system fitted to the vehicle, which uses laser scanners, helps to improve employee safety even further.”
Assistance systems: an optimised workflow for narrow aisles
Two new vehicle series designed for narrow aisles - the PhoeniX 2829-XS and 2921-S - guarantee both safety and compactness.
Besides track guidance and camera systems, it is primarily the HUBTEX Load Manager (HLM) and electronic load chart that help drivers to handle bulky, long or heavy loads. The HLM is an electronic device with 99 freely programmable lift height positions. The lift mast stops at the pre-selected rack compartment level. The system works differently depending on whether goods are being moved in or out of storage, saving valuable time while also reducing the risk of damage to goods in storage. This is because there is no danger of goods being damaged through uncontrolled penetration into the rack compartment.
Another feature, the electronic load chart, uses sensors to record the angle of the fork carrier, the centre of gravity of the load, its weight and its lifting height. The display screen shows the driver how high their goods are allowed to be lifted. Exceeding the permitted lifting height or other parameter thresholds will trigger an overload message. Depending on how it is configured, the system can also instigate overload actions: the lifting process can be stopped automatically, the symbol on the screen can turn red, and an acoustic warning can sound. As long as the symbol stays green, the goods can be lifted safely to their maximum height.
More information about the HUBTEX PhoeniX can be found at https://www.hubtex.com/en-gb/products/electric-multidirectional-sideloaders/phoenix-estl-electric-multidirectional-sideloaders
About HUBTEX Maschinenbau GmbH & Co. KG
HUBTEX is the leading international manufacturer of sideloaders, order picking vehicles, purpose-built industrial trucks and special equipment for transporting long, heavy and bulky goods. The products are designed to enable production and trading companies to achieve an efficient flow of materials and to allow goods handling in the narrowest of aisles. HUBTEX has built up a reputation for comprehensive advice, global service and innovativeness. As a result, the 500-strong company headquartered in Fulda is able to provide the perfect solution for every customer requirement: from basic models to highly developed series trucks and specially developed solutions.
Get in touch with HUBTEX Maschinenbau GmbH & Co. KG
+49-66... Show
Industriepark West
Werner-von-Siemens-Straße 8
36041 Fulda,
Germany
