What makes the BSLBATT the Superior Lithium Battery for your Motive Power needs?
- 31 Mar 2022 ( #1070 )
4 min read
Electric Forklift and Floor Cleaning Machine owners who seek the ultimate performance will find it in the newest release from industry leader BSLBATT Battery Company: the BSLBATT® 48V Lithium-Ion Forklift Battery. As the most reliable forklift lithium battery, the BSLBATT 48V Lithium Battery cycle life to 15% farther than its competitors. It’s ultra-durable, charges fast, relentlessly powers forklifts, and is maintenance-free; making your forklift fleet even better. BSLBATT specializes in manufacturing Li-ion batteries for every forklift.
BSLBATT lithium iron phosphate (LiFePO4) batteries are one of the most durable and reliable energy sources with higher productivity, longer life span, and extended warranty. Our range includes various shapes, amp-hour sizes, and voltages. Making such major investments shows the confidence management has, that once you try it, you'll buy it! The BSLBATT 48V lithium-ion forklift battery had its debut earlier this year at the 2022 China Import and Export Fair Show in Guang zhou, Guang Dong, and will be on display at the Modex Conference in Atlanta Georgia, March 28-31 (booth #C5198).
“The BSLBATT® 48V Lithium-Ion Battery’s industry-leading performance makes it a beast of a battery, specifically designed for performing in multi-shift warehouse applications. Lithium Forklift batteries are quickly becoming the first choice for material handling equipment, forklifts, and airport ground support equipment. and we’re thrilled to introduce it to the market,” said Eric Yi, Chief Executive Officer of BSLBATT Battery Company. “Owners can count on its safety and reliability, backed by BSLBATT’s 20 years of innovation in battery manufacturing.”
Founded in 2003, BSLBATT Battery Company pioneered the first-ever lithium-ion forklift battery in 2012, launching a legacy of leadership in the materials handling industry that continues today.
Among the BSLBATT 48V lithium-ion battery competitive advantages:
Travels farther -
  • Adopting automotive-grade modular design ideas, series products are highly versatile;
  • The mainframe of the structure adopts aluminum extrusion and sheet metal riveting to enhance the mechanical strength and have higher vibration resistance;
  • Use 3000W welding power aluminum bar, low-voltage wiring harness adopts ultrasonic welding/laser welding; higher flow capacity and reliability;
  • Compatible with the modular design of the wiring harness (FPCB flexible cable and AWG wiring harness), the modular plug is foolproof and simplifies the assembly process, which improves production efficiency;
  • The module bracket design reserves the cell expansion gap; it is more conducive to cell life and heat dissipation requirements.
Durability tested - The battery meets SAE vibration tests, lasts two to three times longer than lead-acid batteries, and is backed by 5 years or 10000 hours warranty. Built with one of the highest levels of protection, the battery is also protected from dust, sand, and water.
Certified safe - Field-tested for more than 10000 hours, the BSLBATT 48V Lithium Battery meets international safety and performance standards down to the battery cell level. It is made with one of the most stable chemical formulas (LFP) with redundant safety features, and its battery monitoring system self-protects against short circuits and overheating.
Maximized charger performance - The forklift product adopts the power battery of BSLBATT, which has zero pollution and can be fully charged in two hours, and can work continuously for eight hours. The high-efficiency performance is in line with the internal combustion forklift of the same tonnage. ,You can not only have the surging power of a fuel forklift but also enjoy the low energy consumption of an electric forklift.
Mixed Fleet Support – Compatible with Hyster-Yale, Crown, Toyota, Raymond, Combilift, Jungheinrich, Doosan, Linde, Mitsubishi, and more.
Efficient Software Tools – Integrated WiFi transceivers enable IoT reporting to web-based software that enables better battery and fleet performance.
Advanced Dual CANbus Ports Dual ports support different motive power manufacturers and models, as well as concurrent charging.
Multiple Voltages – 24/36/48/80/96/120/144 Volts up to 1200 Ahr.
Flexible Controls – Operates a wide selection of relays and contactors, multiple programmable I/Os, rollover/crash sensors, and programmable logic controllers.
Maintenance-, hassle- and worry-free. Lithium-ion battery maintenance is as minimal as checking cable connections yearly at most. The BSLBATT 48V Lithium Battery can be stored for up to 12 months in recommended conditions.
Available at local dealers nationwide
The BSLBATT 48V Lithium Battery is now available globally at Authorized BSLBATT Lithium-Ion Dealers. BSLBATT® has one of the largest networks of authorized lithium-ion dealers who are trained to properly upgrade and replace lead-acid batteries with lithium-ion. The new battery will be available globally this year as well.
About BSLBATT Battery
BSLBATT is one of the largest developers, manufacturers, and integrators of lithium-ion batteries for lift trucks in China. BSLBATT supports and guides our distributors to be NO.  1 in the Replacement of Lead Acid Batteries with LiFePO4 Forklift Batteries in the local market. The company sells large quantities of industrial batteries for various equipment. It successfully collaborates with several OEM market leaders.
BSLBATT is a “change ambassador” for the international implementation of the new technology. The company continuously invests in technological development. It has been exploring new chemical compositions that could further reduce the cost of the product while improving performance in order to continue replacing traditional lead-acid batteries. BSLBATT lithium-ion battery systems are built with LFP cells, which have become the benchmark of reliability, longevity, and safety. For more information on BSLBATT Battery, visit lithiumforkliftbattery.com.
For more information, please contact us!
BSLBATT Battery
Factory Address: 1/6/7F-1 Building1 Zhongkai Innovative Base - Huifeng 6th Road ZhongKai Hi-tech Zone, HuiZhou City, Guangdong, China
Office Address: Room 608, Building 1 Zhonghui International Mansion, Huicheng District, Huizhou, Guangdong Province, China
Call us: +86-752-2819469
E-Mail: send an email
Web: www.lithiumforkliftbattery.com
Follow us on Social Media: Facebook | Youtube | LinkedIn | Twitter | Instagram
Get in touch with BSL New Energy Technology Co., Ltd
+86 752... Show
Building 2, Area D,
Qunyi Intelligent Manufacturing Industrial Park,
Tonghu Ecological Intelligence Zone,
Zhongkai, Huizhou, Guangdong,
China
