The Only Explosion Proof Scale on the Market
- 21 Jan 2021 ( #1009 )
RAVAS-226X
The RAVAS-226X is an explosion-proof pallet jack scale, FM certified for use in hazardous areas. Designed for mixing and dosing product batches in the chemical, pharmaceutical, and paint industries, the RAVAS-226X is the only explosion proof unit on the market.
The ATEX certified machine is standard equipped with stainless steel forks, a rotating touch screen display, and special fork dimensions best suited for picking up and weighing reactor vessels. The 226X is an ideal machine to handle the hazardous environments affiliated with batching and dosing solutions.
The exact amounts of raw materials are crucial for recipes' production in the food and pharmaceutical industries. Batching and dosing with a RAVAS 226X scale prevents possible superfluous supply and return of raw materials. When producing a semi-finished or finished product, the aim is to mix the different ingredients and components correctly. Amounts and proportions determine the quality of the product. A mobile scale helps you produce cheaper, safer, and more efficient. It also generates the information you need for quality control, tracking, and tracing procedures. Utilizing a RAVAS-226X for these solutions and industries dramatically increases efficiency and reduces the product's risk of damage.
RAVAS-226X Functions
  • On/Off Key
  • Automatic and Manual Zero Correction
  • Automatic Tare by Push Button
  • Automatic Switch-Off After 30 Minutes of Non-Use
  • 10x Higher Display Resolution
  • LB/KG Toggle
Benefits of the RAVAS-226X
  • Provides Safe Weighing in Hazardous Areas
  • FM Approved for USA and Canada
  • Large, 6-Digit LED Display
  • Rechargeable and Exchangeable Battery
  • Rotating Display, Visible from All Sides During Dosing Operations
  • Stainless Steel Fork Cover
  • 10X Higher Display Resolution for Mixing and Batching
CML Europe
One company taking great advantage of the RAVAS-226X is CML Europe. CML Europe produces raw materials in small quantities for renowned companies in the pharmaceutical industries. For the product organic synthesis to be formed, raw materials must be mixed and separated, warmed up, and cooled down. This all occurs in the reactor vessels after mixing and dosing is done with the RAVAS-226X pallet jack. CML Europe uses the 226X to check the weight and measurement of its raw materials accurately. It can do so safely knowing the pallet jack works efficiently in their hazardous environment.
The RAVAS-226X is more than just a mobile weighing scale. It is an ATEX certified, FM-Approved explosion-proof jack that is dependable, versatile, and ideal for hazardous surroundings. If you are looking for a product that can handle batching and dosing solutions while also being explosion-proof, look no further than the RAVAS-226X.
RAVAS USA is located at 1500 Enterprise Pkwy in Twinsburg, Ohio, and can be contacted at 330.425.3092. Additional information on the company, products, and service can be found at www.ravasusa.com.
RAVAS USA, INC
1500 Enterprise Parkway
Twinsburg, OH 44087
Mail: Send an email
Tel.: +1 330-425-3092
Web: www.ravasusa.com
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
ASSET FINANCE
Nov 2025
