Bolzoni Intelligent Forks
- 17 Dec 2020 ( #1005 )
4 min read
Designed for all forklift trucks, Bolzoni has a complete program of intelligent forks.
Provided as standard fitting on new forklift trucks, forks are the basic attachment. According to the material handling need, the type of load, forklift trucks can be equipped with different types of attachments: paper roll clamps, bale clamps, drum clamps, revolving carriages, etc. Even forks can be upgraded and transformed into ''intelligent'' forks. These modular solutions can be installed on existing side shifters and fork positioners.
Intelligent forks are a great help to the forklift truck driver during loading, unloading and warehousing operations, in particular when moving pallets at high levels on shelves and during forklift manoeuvres.
The Bolzoni program of intelligent fork solutions
Designed for all forklift trucks, Bolzoni intelligent forks have a robust design and are available in different sections and lengths. "It's a matter to improve safety and efficiency inside the working place," says Lorenzo Masoni, Bolzoni Group Fork Product Manager. "To equip forks with a camera allows to quickly engage the handling load, and to move in safety. Furthermore, in order to save time, the fork with the integrated weighing system is able to weigh the handling load, and to save data through an App."
Camera fork mounted: Easy-FORK
Designed for all forklift trucks, the Bolzoni Easy-FORK range significantly increases safety in the storage areas.
Easy-FORKS with camera fitted on the inner right fork side.
Fork mounted side camera
Thanks to the camera position, the driver can have a clear view on both forks, with a horizontal 52-degrees viewing angle, while maintaining the correct ergonomic position on the seat.
Camera images are displayed on a 7 inch. monitor installed inside the driver cabin. The connection between camera and monitor can be wireless (standard) or through a reinforced cable and cable reel. Easy-FORK are factory and aftersales solutions, available in customized and adapted configurations (cable reel as option).
Easy-FORKS with camera fitted in the right fork inner tip.
Fork mounted tip camera
This type of solution allows the complete visibility upfront even when the load is on the forks. The robust IR camera has triple LED lights and is completely integrated in the fork tip. The connection cable remains inside the blade. By means of the led lights, the loading is made safe even in low light conditions.
Thanks to the camera position, the driver can have a clear view on the area, with a horizontal 52-degrees viewing angle, while maintaining the correct ergonomic position on the seat.
As for the lateral camera fork version, camera images are displayed on a 7 inch monitor installed inside the driver cabin. The connection between camera and monitor can be wireless or through a reinforced cable and cable-reel.
The Easy-FORK Vision Systems range includes the Side fork camera, the Tip fork camera, and a modular solution to be installed on the fork carriage, including Front camera and laser, which is under development.
The installation of the RAVAS scale forks iFORKS-32 on the forklift truck takes 5 minutes.
Forklift Truck Scales: iFORKS-32
Installed in minutes, scale forks are used to directly weigh loads during the transportation through forklift truck and to keep track of the load weight data.
These are powered by compact Lithium ion battery packs, without cabling, and have all weighing components well hidden below and behind the fork shoe.
The high accuracy weighing is obtained thanks to the automatic compensation of the mast tilt. This function automatically corrects weight errors that occur when the mast tilts and the forks are not in horizontal position.
Finally, the weighing data are transferred via integrated Bluetooth. Thanks to the RAVAS WeightsApp, available on Google Play and App store, the smartphone or tablet act as a remote display and remote control for the scale.
"This high technology RAVAS product has been distributed by BOLZONI since August 2020," says Lorenzo Masoni, Bolzoni Group Fork Product Manager, "and we highly recommend this product in combination with the fork positioner."
The RAVAS scale forks are easy to install on the  Bolzoni Auramo and Meyer fork positioners. Here fitted on a MEYER 6-2504 shaft guided model.
Material tracking and certified quality since 2007
Since 2007 Bolzoni has designed and produced a complete range of forks for lift trucks, construction and agricultural material handling machines, in many different capacities, sections and lengths, ISO and special mountings.
In the two dedicated manufacturing plants, in Piacenza, Italy and in Longhua, PRC, Bolzoni annually produces about 400,000 units.
All Bolzoni forks comply with the parameters outlined in ISO 2328 and 2330, with certified quality of chemical composition and of the heat treatment applied on the raw material. Bar coding allowing for the tracking of raw material back to source.
Bolzoni forks are fitted worldwide ex factory at OEM premises and are suitable for after-market specialists too.
Mr. Lorenzo Masoni, Bolzoni Group Fork Product Manager and Intelligent Forks Specialist for the Bolzoni Group.
For more information on Intelligent Fork solutions, contact Lorenzo Masoni, Bolzoni Group Fork Specialist. Send Lorenzo Masoni an email.
Ask him about our references on Intelligent Fork Solutions, or to organize a demo unit at your facilities. We have a demo kit ready for you.
For more information on BOLZONI forks, please visit our website www.bolzonigroup.com and contact us by email, or contact the nearest BOLZONI AURAMO and MEYER representative.
____________________________________
Bolzoni Auramo is a Bolzoni Group brand.
