Bolzoni Auramo - Partner in Construction Material Handling
- 16 Jul 2020 ( #983 )
4 min read
Bolzoni Auramo attachments are robust and wear-resistant: they perfectly fit into the process of handling builders goods, such as cement, engineering bricks, concrete bricks, block paving, concrete pipes, oversized structures, precast concrete products, and kerbstones.
Durability, serviceability and performance: Bolzoni Auramo and Meyer attachments are robust and wear-resistant, while maintenance costs are reduced to the minimum.
Get a heavy-duty grip and boost productivity
Organization in construction sites is very complex. From a logistics point of view, building material has to be available and ready for use. Often stocked in open-air areas, bulky, heavy material with various shapes and irregular surfaces is transported to different construction yard areas by forklift trucks.
Construction material companies, specialized in the supply of heavy materials to builders and civil engineering contractors, find a reliable partner in Bolzoni Auramo and Meyer forklift truck attachments.
Bolzoni Auramo and Meyer attachments perfectly fit into the process of handling builders goods, such as cement, engineering bricks, concrete bricks, block paving, concrete pipes, oversized structures, precast concrete products, kerbstones. As a matter of fact, Bolzoni Auramo and Meyer attachments are designed to withstand the tough environment of the construction material industry, with an optimal design for yard work.
Heavy-duty fork lift truck attachments
Bolzoni engineers are ready to understand the customer requirements for ensuring on-site safety and increased productivity during all handling situations. Bolzoni Auramo and Meyer attachments handle products in the safest and most efficient way, without any damage to the products.
The Range
Bolzoni Auramo and Meyer offer a wide range of forklift attachments in the field of construction with a variety of capacities openings range and other technical specifications: fork positioners, pallet fork clamps, block clamps, concrete pipe clamps, forks and lifting tables. Bolzoni Auramo and Meyer attachments for construction material are reliable in all environmental conditions, thanks to the great visibility to the truck driver. Furthermore, the reduced attachment weight and center of gravity grant higher stability during the transport and high residual capacity.
Brick and Block Clamps
Brick Clamp: Designed to compensate the load irregularities typical of the bricks, this clamp has special execution arms fitted with self-aligning hard rubber blocks.
The Bolzoni Auramo brick and block clamp with self-compensating pads is used to handle concrete blocks, without the use of pallet.
Designed to compensate the load irregularities typical of the bricks, the clamp has special execution arms fitted with self-aligning hard rubber blocks. These are floating on a chamber filled with glycerine. While clamping, the chamber adhere against the rubber blocks, which adapt to the load irregularities. Available also with oscillating arms.
Concrete Pipe Handler
Robust Concrete Pipe Handler to lift, carry and rotate pipes in full safety.
Concrete pipes are manufactured in a great variety of diameters, widths and weights. Bolzoni Auramo has designed strong and accurate clamps to lift, carry and rotate pipes in full safety.
Heavy-Duty Multi Pallet Handler
Heavy-duty Meyer Multi Pallet Handler with fully encapsulated Shaft Guide, to endure the rough operating conditions.
Multi pallet handlers are useful to transport concrete bars, heavy shingles on Euro and non standard pallets, roof tiles and any palletized goods. Meyer heavy-duty multi pallet handlers are extremely robust. The fully encapsulated Shaft Guide Concept of Meyer Pallet Handlers resists the rough operating conditions. The attachments have maintenance intervals perfectly falling in line with those of the lift trucks. The excellent visibility eases the handling and contributes to the overall low operating cost of the attachment.
Fork Positioner
Heavy-duty fork positioners work in all-weather outside operation.
The heavy-duty fork positioners for the concrete industry work in all-weather outside operations with heavy dirt and dust contamination. With separate sideshift, equal fork travel, long-term endurance wearing parts they guarantee excellent performance in tough environmental conditions.
Other Applications
Rotating Clamp fit for heavy-duty purposes.
Bolzoni Auramo and Meyer forklift attachments are fit for heavy-duty purposes, in difficult and dirt environment conditions. Fabric rolls boom attachments, wooden boards clamps: get in touch with our Technical Engineers, to study together the most suitable handling solution for your heavy-duty material handling need.
Lift Tables
Scissor Lift Table to lift and lower loads at the required height.
Bolzoni scissor lift tables represent in many cases the best solution concerning functioning, cost saving, safety and health of operators in the workplace for the handling and lifting or lowering the loads at the required height.
A wide range of models and capacities for use in production process, loading of vehicles, workstations in automated lines and heavy applications, allows us to provide the best and customized solution also in hard application as building material handling.
For more information on Bolzoni Auramo products, please visit our website www.bolzonigroup.com and contact us by email, or contact the nearest Bolzoni Auramo representative.
____________________________________
Bolzoni Auramo is a Bolzoni Group brand.
As part of Forkliftaction’s 25th anniversary celebrations, we have dug into the archive and, over the next year, will be highlighting a carefully curated selection of historical stories we have published over this time... Continue reading
IMHX to become a biennial event Birmingham, United Kingdom
October 8-9, 2025 - Twickenham, United Kingdom
