CVS Ferrari’s new family of reach stackers
- 19 May 2005 ( #209 )
CVS Ferrari has produced a new family of reach stackers from the last generation, the 300 series. This family embodies the evolution and the improvements that CVS Ferrari reached in terms of quality, technology, innovation. The new reach stackers models (i.e. F365, F377, F378, F379, F381, with all the different equipment such as piggyback and barge handling) are the result of the large experience that CVS Ferrari has developed throughout years of studies, testing and production.
CVS Ferrari has introduced important innovative technologies ever since 1997. Our competitors have just started to introduce similar technology without having the same experience as CVS Ferrari.
Here are the most important technological innovations on Ferrari 300 reach stacker:
CANBUS technology that reduces the cabling complexity with consequent reduction of the number of cables:
  • the cable testing operations are considerably simplified
  • the number of connectors are reduced
  • the assembly costs are reduced
  • the information can be shared hence eliminating the necessity of redundant sensors
  • the flexibility of the system is increased and new functions can be added
  • a complete diagnostic function is available, simplifying repair intervention
HYDRAULIC SYSTEM based on variable displacement pumps and load sensing distributor of the third generation, that reduces and limits to the minimum the energy consumption of the machine. This revolutionary distributor works on the logic of distributing the flow regardless of the load to avoid cutting off any of the demands on oil. It is really possible to combine any sort of movement of the mast and spreader together with the steering without
any drop in the machine performance. The other advantage is the reduction in fuel consumption around 30-40 %. The distributor is controlled by a joystick, having proportional control.
Other Ferrari 300 characteristics:
CABIN:
  • Interactive full colour display
  • New dashboard
  • Cabin with steel frame meeting new F.O.P.S. norms
  • Hydraulic joystick vertical lifting capability
  • Adjustable armrest
REAR VISIBILITY:
  • Noise Level 75 Dba DIN 45635
  • ISO 13564 visibility standard
STEERING AXLE:
  • Fully protected bushings with cover and seals
  • Greasing from top to bottom
  • New steering cylinder easy maintenance
  • Lateral shock absorbers free maintenance more stability
  • Flexible silent block coupling between rear axle and chassis
  • New bushing high thickness low wear
CHASSIS:
  • Certified automatic welding process ISO 9001
  • Provision for optional: hydraulic sliding cab
    hydraulic lifting cab
    hydraulic front jacks
  • F 300 family meet DIN 15018 structural design standard H2 B4
SPREADER:
  • C.V.S. design and manufacturing
  • Two hydraulic gear motors smooth braking best reliability
  • Single beam spreader
  • all cylinders are located externally easy maintenance
  • SMOOTH HANDLING Two dumping cylinders
  • Full floating twist locks
  • Electrical and mechanical safety system at each twistlocks casting
  • 45 tons lifting capacity high grade quality steel
ELECTRIC SYSTEM:
  • Water-proof connectors military type
  • Maximum Protection IP 65 grade, modular and expandible
  • Automatic circuit breakers on spreader
  • Auto-diagnostic capability
  • Programmable
  • Black box
  • Printed Circuit Board Technology no relays
  • Data transfer via GSM system
HYDRAULIC SYSTEM:
  • Lower noise level
  • Third generation LUDV load sensing system
  • Fully hydraulic operation (no electronics)
  • Full performance at lower rev.
  • Lower fuel Consumption
  • High integrity variable displacement swash-plate piston pumps
  • Leakage free hydraulic components
  • Designed for easy maintenance and trouble shooting
  • Standardization on system components
Contact CVS Ferrari
