|  VETTER BigForks - for safe handling of heavy loads. |
According to the Olympic motto "higher, faster, further", VETTER's credo is "bigger, stronger, longer". With the most comprehensive range of large forks, VETTER BigForks can be used wherever efficiency, safety and endurance are required.
With load capacities up to 120 tons and blade lengths up to 5,000 mm, BigForks offer solutions for almost all applications where heavy loads are moved.
From the wood and chipboard industry to steelworks, quarries and construction sites to container transport and port logistics.
|  Fully automated heat treatment plant. |
Superior technology and most modern productionVETTER BigForks are the benchmark for quality and performance. BigForks pass the strictest quality controls in the world's most modern production facility for large forks. High-performance steel grades VQ32+ and VQ 1300 are optimized for their specific usage, as only the best steel ensures that the forks withstand extreme stresses and strains. Strength, toughness, purity, hardness and workability are optimally coordinated and guarantee continuous long-term use. But steel quality is not the only decisive factor. Precise, high-quality mechanical processing, a special, fully automated heat treatment and the welding-competence certified according to ISO 3834-2 make VETTER BigForks a superior quality product.
The special manufacturing method generates tight tolerances and smooth surfaces, a unique feature that makes BigForks by VETTER a perfect example for excellent reproducibility. Apart from that, this process allows the OptimaForkHeel to be shaped with an additional wear zone for less deflection and ideal stress distribution, which ensures high safety and extends the life of the BigForks considerably. This is a unique selling point for forks of this size.
| |  Worldwide most modern production for BigForks. |
The production of forks is subject to continuous process monitoring in order to maintain strict quality standards. After all, it is a safety product and therefore has to meet highest standards - no compromises!
|  BigForks for coil-transport with spray-coating. |
Customized solutions for your special applicationVETTER is Europe's No. 1 independent and family-owned fork manufacturer.
The most comprehensive product range provides solutions for almost all applications, standard or customized: Forks in all sizes for almost every customer-specific requirement!
It makes VETTER to be the one-stop-shop for all your demands.
In addition, customers receive an all-round carefree package: starting with the most modern order processing, design service, complete documentation through to optimized and customer-specific packaging solutions, repair service and training service for technicians and sales staff.
| |  Roller-guided & height adjustable BigForks 400x80 mm. |
 | |  Cranked BigForks. |
VETTER Industrie GmbHCarl-Benz-Straße 45
57299 Burbach
Tel: +49 (0) 2736 4961-0
Email: Send an emailWeb: www.gabelzinken.de |
www.smartfork.com
