Your Lithium Ion solutions from Battery Supplies
- 5 Mar 2020 ( #964 )
Battery Supplies, your supplier for all batteries, chargers and accessories since 1999. The widest variety of batteries on stock in our 10.000 m2 state-of-the-art warehouses and offices. 90 dedicated colleagues ensuring best price offers & correct transport delivery. Battery Supplies is your one-stop-shop for all your battery needs, a partner you can rely on!
During LogiMAT (Hall 10, Stand B66) we want to highlight our wide variety of customer-friendly lithium battery solutions:
1. Custom-made packs for small and big applications
  • Li-NMC-O2 or LiFePO4
  • Cylindrical or pouch cells
  • Voltage <48V
  • Capacity up to 40Ah
  • Different C-rates (for storage of energy or power applications)
  • Built-in protective PCB, cell balancing
  • Dimensions according to request
  • Soft PVC or aluminum housing
2. Easy-to-use drop-in replacement AQ-LITH® LifePO4 batteries, available in 12V, 24V and 48V, up to 300Ah
Our Lithium Ion drop-in replacement batteries can directly replace your current SLA batteries in many applications. They have an excellent lifespan of up to 2000 cycles. These maintenance-free batteries have the same dimensions as SLA batteries but are much lighter (up to 70% lighter) and have much better performance and economic life. The drop-in replacement batteries are extremely safe: they can charge quickly without overheating and gasification, they are also protected against overload and full discharge thanks to the built-in BMS.
Also from an ecological point of view, there are only advantages: these batteries contain no acid, no lead and no other toxic substances.
3. AQ-LITH® Modular blocks: series and parallel connection
  • LIFEPO4
  • MODULAR
  • SERIAL & PARALLEL CONNECTION
Our unique AQ-LITH® M+ Series modular LiFePO4 system that combines the flexibility of a custom-made solution with the simplicity of a block battery system. Many vehicle manufacturers have chosen this option!
4. AQ-LITH® Custom build with own Battery management system (BMS)
Do you need a special battery for a specific application? No problem! Give us the desired voltage (12, 24, 48, 80, ... volts), the required capacity and the dimensions and Battery Supplies makes a unique battery. For this we use 3V cells and our own developed BMS.
We supply a range of next generation, proven Battery Management Systems that will work for all high-power lithium batteries commonly used in a range of Electric Vehicle (and other) applications.
They are highly configurable in both hardware and software, allowing a range of battery systems from a few cells up to hundreds of cells. The modular design allows systems to be easily expanded with your needs, reconfiguring as required.
Advantages:
  • Quick & opportunity charging
  • Maintenance free
  • Cost-effectiveness
  • Zero-emission
Battery Supplies N.V.
Nijverheidslaan +50/56
8540 Deerlijk, Belgium
Tel.: +32 56 617 977
Fax.: +32 56 617 955
E-mail: Send an email
Web: https://batterysupplies.be
