STAXX: Logimat 2019 Preview
- 14 Feb 2019 ( #910 )
As one of the innovator or material handling equipment industrial, STAXX always aims to 'Make Your Job Easier'. STAXX will exhibit from 19th to 21st February 2019 in Hall 10, Stand No. D73, on the LogiMAT in Stuttgart.
ACQ QUICK LIFT Hand Pallet Truck
STAXX QUICK LIFT Hand Pallet Truck ACQ
DUTY FREE PALLET TRUCK for EU market (NO ANTI-DUMPING DUTY, 0% IMPORT DUTY)
ACQ model with AC QUICK LIFT pump is able to lift pallets under 280kgs by 3 times pumping ONLY! Help the user greatly increase efficiency and productivity.
See the YouTube videos:
Factory introduction video | ACQ introduction video
WH-25ES High Precision Weighing Scale Pallet Truck
STAXX High Precision Weighing Scale Pallet Truck WH-25ES
  • 2500/3000kg capacity; 500g accuracy
  • Electronic indicator with 32mm high red LED display
  • Four load cells ensure accurate readings in kg or lb
  • Printer and full stainless version available.
STAXX 24/7 Series Lithium Battery Powered Pallet Truck showing at LogiMAT
  • Built to work 24 hours lead to the 24/7 series PPT18H and EPT15H.
  • Thanks to the 0.75 brushless motor and lithium battery, this series is almost maintenance free and easy service at anytime for easy battery change in seconds.
  • Smart size, Smart function, so easy maintenance, robust, cost-effective make the 24/7 series is a idea unit to replace your hand pallet truck and get rid of heavy daily work.
PPT18H Semi-Eelectric Lithium Battery Powered Pallet Truck
EPT15H Full-Eelectric Lithium Battery Powered Pallet Truck
See the YouTube video:
STAXX Light Duty Electric Stacker PWS and WS Series
  • Built to replace semi-electric stacker, capacity from 1000kgs to 1500kgs, lifting height from 1.6m to 3.5m. Ergonomic design, cost-effective.
  • Remote control option, free Lift option on duplex mast!
PWS Introduction Video | WS12S Free lift video
Economical Full electric stacker PWS Series
Full Electric Stacker WS12S Series
See more at LogiMAT 2019 - Hall 10, Stand No. D73!
NINGBO STAXX MATERIAL HANDLING EQUIPMENT CO.,LTD
Thomas Wang
0086 574 8921 7230
+86 187 5839 2207
send an email
www.staxx-mhe.com
STAXX ShopFront
