P.B.M. launches new ON-BOARD chargers
- 17 Jan 2019 ( #906 )
PBM leading Company in battery charger production since 1973 launches a complete range of UL listed on-board chargers.
PBM battery charging solutions are available at several power levels appropriate for electric vehicles and industrial equipment.
Our industrial battery chargers satisfy internal safety requirements, reliability and quality.
HF799, HF1000, HF1200, HF1400 Series battery chargers are IP65-rated to withstand tough environments and are protected against high vibrations, extreme temperatures and water, chemical and dust ingress.
HF799. Click for larger view.
HF1000. Click for larger view.
HF1200. Click for larger view.
HF1400. Click for larger view.
Capable of charging lithium-ion and lead-acid (wet, AGM, gel) batteries, the series of chargers was built following customer needs. The range is equipped with USB host port for charge cycle data download and software updates.
The range is available from 12V to 48V and all of them produced in extended range 100-240VAC +/-10%.
Within this range, the HF1200 is one of the most compact chargers available, and is able to be installed inside the DIN battery pack.
Discover more about PBM products on our web site.
P.B.M. srl
Maurizio Pelloni
+390597705321
+393356100449
Send an email
www.pbmbatterychargers.com/en/
