Planetary Gear Bearings For Material Handling Vehicles
- 16 Aug 2018 ( #885 )
RNN Bearing from CCTY Bearing
After two years in development and extensive testing, CCTY Bearing is unveiling its newest bearing series, the RN and RNN full complement cylindrical roller bearings.
Planetary gears require immense power to move material handling equipment while operating within a compact design. This series from CCTY Bearing needs only a small amount of radial space and provides heavy load capacity.
Low friction, long life and high reliability are necessary bearing attributes for industrial gearboxes performing under dynamic and static loads that can reach their physical limits. The RN and RNN series meet performance requirements and feature:
  • Low noise and vibration
  • Compact design
  • Single Row Planetary Gear Bearing
  • Precision grinding and super finish
  • Uniform contact stress from an optimized crown profile on raceways and rolling elements
  • RNN guide ring availability
  • Surface treatment options to improve life, durability and speed
The cage-less design has optional features include guide ring, flange and surface treatments.
Double Row Planetary Gear Bearing
Information about the RN/RNN series can be found on CCTY's website,
CCTYBearing.com/cylindrical-roller-bearing
TAKE THE NEXT STEP
Ready to see how your planetary gear box can benefit from standard or custom cylindrical roller bearings from CCTY Bearing? CLICK HERE
Please contact:
CCTY Bearing
8475408196
send an email
www.cctybearing.com
