RAVAS introduces iForks-32 the new generation forklift truck scale
- 3 May 2018 ( #870 )
iForks, the hugely successful RAVAS scale forks, have moved into their next generation! With only 58mm fork height and no external components on the fork shank, iForks-32 looks more and more like standard lift truck forks.
BYE BYE BIG BATTERY PACKS.
iForks-32 looks leaner than its predecessor: the big battery packs have been eliminated and replaced by more compact Lithium ion batteries that supply the same capacity and more reliability. All scale components on the forks are now hidden below and behind the fork shoe, creating a slick, efficient look for iForks-32.
The changes to batteries and Bluetooth modules, and the elimination of the cover plates, leave no external components on the fork shank, making iForks-32 even more easy to fit onto fork positioners. And since machining of the fork shank is no longer needed, the structural strength of the forks has increased, making it possible to reduce the fork height to only 58mm. iForks-32 is now only marginally higher than standard lift truck forks.
High accuracy: automatic compensation for mast tilt
The 3200 weight indicator offers interesting improvements, compared to the previous 3100. Its functions now include automatic tilt compensation, to automatically correct weight errors that occur when the mast tilts and the forks are not in horizontal position. And the 3200 instrument automatically logs tip loads and overload events.
Bluetooth 4.0 is a standard feature on the 3200, providing connectivity to PDA's, tablets and smart phones. A RAVAS app is available from Google Play and the App store. It acts as a remote display and remote control for the scale, but also allows you to download data from the 3200 instrument and send it off via email.
iForks-32: all USP's at a single glance
  • Advanced 3200 driver display
  • No cabling, no external components
  • Standard fork shank, easy installation, fits on fork positioners
  • Forks are only 58mm high
  • Compact Lithium Ion battery packs
  • Automatic tilt compensation
  • Overload and tip load logging
  • Bluetooth 4.0 as a standard feature
  • With user and service app
Please Contact:
Sales Team - RAVAS Europe BV
P: +31 418 515 220
E: send an email
W: www.ravas.com
About RAVAS
RAVAS
manufactures and distributes weighing systems integrated in hand pallet trucks, warehouse trucks and forklift trucks. These mobile weighing systems enable companies to realize immediate cost savings, to make their internal logistics more efficient, to raise the quality of their products and services and thus increase client satisfaction. In today's world of integrated information RAVAS strives to give all its products optimal connectivity. This means that weight information from RAVAS mobile scales can be easily integrated with other information about material flows. The resulting data set can be fed directly into an ERP or WMS system.
