Look Out For Landoll Corp
- 16 Dec 2004 ( #188 )
Landoll Corp. will be demonstrating the new Series IV model BN 180 degree articulating mast Bendi. This truck easily stacks standard 48" x 40" loads in 6' aisles and is available in 2,500 and 3,500 lb. capacities and lift to 26'. Additionally Landoll Corp. will be demonstrating the Bendi Series IV model B40 electric equipped with extending forks for storing loads 2 deep. Recent Series IV improvements include higher capacity planetary transmissions, dual full time drive traction motor controllers, transistor controlled hydraulics and major improvements in the steering and hydraulics as well as a 10% increase in battery capacity. Also on display will be the Landoll manufactured Drexel 3 wheel VNA truck model SLT30 which stacks in 56" aisles and the 4,000 lb. capacity LP Gas Bendi which is available with triple or quad masts and lift heights to 26'. The LP Gas Bendi will be equipped with a new fuel system that meets all the current EPA standards for emissions in all 50 states.
Company Profile:
Landoll Corp. which celebrated its 40th anniversary in December 2003, is located in Marysville, KS and is a diverse manufacturer of products for the Material Handling, Transportation, Agriculture and Specialty Government markets. The Material Handling Products Division manufactures forklifts that operate in aisles as narrow as 4 1/2' with lift heights to 33' and capacities from 2,500 to 12,000 lbs. The Forklifts include the original and increasingly popular Bendi 180 degree articulating mast, front wheel steered, rear wheel driven electric and LP Gas powered trucks. The Bendi electric line was recently expanded to include 2 new models that work in aisle under 6' with 2,500 and 3,500 lb. capacities. This allows the Bendi to cross over into the existing turret truck market where aisles normally approximate 6'. Landoll also manufactures the Drexel Line of SwingMast trucks, which are designed to operate in aisle as narrow as 4 1/2' and for long load handling in narrow aisles as a sideloader. An EX rated explosion proof Drexel front-loading model is also available for those customers who need a forklift to operate in flammable or explosive atmospheres. Both the Bendi and Drexel SwingMast forklifts provide maximum utilization of storage space by reducing aisle sizes while still performing all the jobs of a front-loading forklift. This includes loading and unloading trailers, going from the dock to the rack without staging, climbing ramps and working in a variety of applications. Options are available for different applications including a wide range of attachments, freezer conditioning and EE Spark Proof rating for hazardous area storage. Landoll Corp. now provides the widest range of solutions to those customers wanting to minimize storage aisle sizes, and maximize productivity and equipment utilization. Innovate new designs and continuous product improvements keep Landoll in its position as a leading provider of these narrow aisle and very narrow aisle forklifts. Landoll's production facilities consist of over 400,000 square ft. of modern manufacturing space and the latest in CNC machining stations. Landoll distributes and supports its forklift lines through over 100 independent dealers worldwide who are trained to analyze applications, make recommendations and provide after market support through factory trained service and parts departments. Landoll is also ISO 9001 Certified.
Key benefits:
Landoll narrow aisle forklifts:
* Convert wasted aisle space to valuable and productive storage space.
* Operate in truck loading and unloading operations as well as in the narrow aisles allowing one truck to do it all.
* Works rail cars, ramps, drive in/ through rack, push back rack and outdoors.
December 03, 2025 - New Delhi, India
