Are picking errors costing you money?
- 2 Nov 2017 ( #845 )
RAVAS mobile scales on your order pick trucks signal picking errors Correct picking errors where the cost is lowest: at the picking slot!
Picking errors create unnecessary cost: lost or returned goods, stock differences, credit notes, phone calls, emails back and forth. Watch our video and see how a RAVAS scale on your order pick trucks signals picking errors and enables you to correct these errors immediately, at the pick location, with the least possible cost. Realize immediate cost savings!
Pick by weight: how does it work?
The weighing scale integrated in your order pick trucks continuously measures the weight on the forks. The scale display is connected to your warehouse management system via wireless. After each pick, the WMS interrogates the scale for the weight increase on the forks. It compares the actual weight on the forks with the combined weight that the articles in the order line should have. If the picker has picked the wrong article, or an incorrect number of articles, the WMS sends an error message to the picker next to the truck, and the picker corrects his mistake. Picking errors are corrected where the cost is lowest: at the pick location.
Works in combination with Pick-by-Voice, works for batch picking strategies, works on every make & model truck.Download our brochure and learn all about it!
Benefits & advantages
  • Cost reduction from eliminating errors
  • Cost reduction from cancelling final inspections
  • Performance of each individual picker monitored
  • Improved supply chain control
  • Documented quality of your services
RAVAS Europe BV
P: +31 418 515 220
E: send an email
W: www.ravas.com
About RAVAS
RAVAS
manufactures and distributes weighing systems integrated in hand pallet trucks, warehouse trucks and forklift trucks. These mobile weighing systems enable companies to realize immediate cost savings, to make their internal logistics more efficient, to raise the quality of their products and services and thus increase client satisfaction. In today's world of integrated information RAVAS strives to give all its products optimal connectivity. This means that weight information from RAVAS mobile scales can be easily integrated with other information about material flows. The resulting data set can be fed directly into an ERP or WMS system.
