RAVAS at the LogiMAT: Pick by Weight and SafeLoad
- 9 Feb 2017 ( #807 )
Pick by Weight: RAVAS mobile scales on order pick trucks signal picking errors
Errors in order picking mean lost or returned goods, stock differences, credit notes, phone calls and e-mails back and forth: loss of goodwill and a burden on the organization. RAVAS will show how weighing scales built into the forks of an order pick truck help you to realize immediate cost savings by eliminating picking errors.
A novelty on the stand will be RAVAS-SafeLoad: a safety product for forklifts that provides both weight and stability information and acts like an interactive load diagram that warns the lift truck driver in case of unsafe lifting.
A RAVAS weighing scale built into the forks of an order pick truck allows you to check each individual pick on-line. Picking errors are signaled instantly and corrected on the spot, where the cost is lowest: at the picking slot, before the picker moves on to his next pick location. ROI studies have shown that payback time on the weighing scales is often less than a year, and that considerable cash flows are generated over the lifetime of those scales.
Weight and stability indication for forklift trucks
RAVAS-SafeLoad: both weight and stability info on forklift trucks
The RAVAS-SafeLoad is an aftermarket safety product that can be installed on any make and model counterbalanced truck and reach truck. It functions as an interactive load diagram that continuously advises the driver about the stability of his truck in the current lifting situation, and warns him when the lifting is considered unsafe. No more tipping over or breaking forks.
All this and much more at the RAVAS stand at the LogiMAT show: Hall 9, Stand 9A08.
RAVAS Europe BV
P: +31 418 515 220
E: send an email
W: www.ravas.com
About RAVAS
RAVAS
manufactures and distributes weighing systems integrated in hand pallet trucks, warehouse trucks and forklift trucks. These mobile weighing systems enable companies to realize immediate cost savings, to make their internal logistics more efficient, to raise the quality of their products and services and thus increase client satisfaction. In today's world of integrated information RAVAS strives to give all its products optimal connectivity. This means that weight information from RAVAS mobile scales can be easily integrated with other information about material flows. The resulting data set can be fed directly into an ERP or WMS system.
