wuBump® cover on fork of pallet-jack, pallet-truck and stacker
- 9 Feb 2017 ( #807 )
wuBump® has developed a plastic fork cover that mounts on the forks of a pallet-jack, pallet-truck or stacker. The plastic fork cover avoids slipping of the load on the forks and scratching of the load by the bare steel forks.
The wuBump fork cover consists of a granular upper layer with a high friction coefficient that is 5 times higher then the friction coefficient of the steel fork blade. The high friction of the wuBump fork cover avoids slipping of the load when the truck is braked or when the truck drives on a slope (i.e. when loading a lorry).
WATCH OUR LATEST VIDEO HERE!
As the high friction layer is only 3mm thick, the smooth entry of the forks into the opening of a pallet is not affected.
In the standard version, the back side of the wuBump fork cover is self adhesive which allows an easy installation:
Optionally, a magnetic layer (1.5mm thick) can be added to the back side of the wuBump® fork cover making the mounting and dismounting of the wuBump® fork cover even more user friendly. Dismounting the magnetic wuBump® fork cover when not in use decreases the wear of the plastic fork cover thus increases the lifetime of the cover:
In order to avoid damage to the load, wuBump® offers in addition of its fork cover a variety of plastic shock absobers that can be installed on the fork back of a palletjack, pallettruck or stacker. These shock absorbers are easily clicked on with magnets. The wuBump plastic shock absorbers have a resilient fiber structure and avoid a heavy contact with a fragile load:
For more information on wuBump products, please visit our website www.wubump.com or send an email.
Wuylens Engineering - wuBump®
P: +32 (0) 92 65 02 28
E: send an email
W: website
ABOUT US
Wuylens Engineering has over 25 years of experience in the technical reconstruction of low and high energy collisions. Wuylens Engineering was founded as an engineering & consulting firm but has changed over the years into a manufacturer of safety products for industry and logistics. Wuylens Engineering has developed, produced and patented several resilient shock absorbers under the brand name wuBump®. Wuylens Engineering is dedicated to innovate new products to help the industry to avoid costly collision damage and downtime of machines and operators.
