New profile guided MEYER Multiple Pallet Handlers - benchmark in Robustness and Flexibility
- 22 Dec 2016 ( #801 )
Designed for the most arduous applications
The new Profile Guided Pallet Handler stands out in many aspects: the chassis and arm design underwent an extremely demanding cycle test with a load twice the nominal capacity that it is designed for. "We stopped after we surpassed 1 Million cycles because, the unit simply didn't show any defects so, we are very confident we are presenting an extremely robust design - no other products that underwent exactly the same test procedure achieved comparable results" Ingmar Grabbe Product Manager Beverage Logistics at MEYER GmbH, proudly explains. Next to its robustness the new design embodies the typical product advantages that MEYER Pallet Handlers are well appreciated for: cleanliness in operation, fast operation speed with equal forks travel, and an optimum of visibility on all operation levels.
Profile System
Maximum flexibility in Operation
Applications and demands constantly vary - besides typical standard operations, many applications require a specialized product, either for handling various non-standard load sizes, or to accommodate the many demands for special fork opening ranges and very often also fork settings and open / closing sequences.
The new MEYER profile guided Pallet Handled is engineered just around such demands: the design allows a quick and easy change-over of fork setting distance, the fork sequencing and even the opening range with a minimum of additional parts required.
Mr. Grabbe underlines: "We also incorporated a Dual Mounting concept into the new Attachment Chassis, which allows to switch over from ISO 2328 Mounting Class 2, to Class 3 and vice versa, using just one single sideshift arrangement - this significantly supports fleet users and rental fleet operators to have flexibly for reacting to Fork Truck availabilities and changing or fluctuating applications. The challenge for our engineers was to design a Chassis with an optimum of visibility at all sight levels, which we perfectly achieved"
Optimised towards a minimum of Total Cost of Ownership
Fork Truck and Attachment Fleets, usually nowadays, operate a full maintenance lease contract and are targeted to a minimum of maintenance requirements. Wherever wear and tear is unavoidable the related components are expected to last over the longest possible period of use.
Mr. Grabbe explains further: "With this new design concept we were able to almost eliminate all wearing components and, the consumable components fitted have an extremely long-life characteristic and can be exchanged within a few minutes. Together with the Technical University of Clausthal-Zellerfeld in Germany we analyzed the state-of-the-art plastics, which optimally combine robustness and long-life with high self-lubricating characteristics".
"When it still comes to exchanging these Plastic Inserts with our new Profile Concept, it just takes a few minutes to change them",
Mr. Grabbe highlights.
The new MEYER profile guided Multiple Pallet Handler
The new MEYER Profile Guided Pallet Handler is fully designed around the concept of optimized Total Cost of Ownership by a minimized number of wear parts, long life wearing components, minimized maintenance requirements with reduced labour time.
Fitting and removal of the plastic inserts
New profile guided Pallet Handler being released to all markets now
After a successful introduction to the market of the United Kingdom on this year's IMHX Materials Handling Show, the new profile guided pallet handler is currently being released to all markets.
For more information please contact us:
MEYER GmbH
P: +49 5341 803-114
E: send an email
W: www.meyer-world.com
SF: Visit the MEYER ShopFront
Gittertor 14 * 38259 Salzgitter * Germany
