Wire Industries Buys New Mobicon 2T
- 24 Nov 2016 ( #797 )
Mobicon 2T - Designed to work under awnings & in the warehouse
Wire Industries has purchased a new Mobicon 2T for their Brisbane manufacturing operation after an extensive search for the right container handling machine to meet their requirements.
"We purchased the Mobicon 2T for its 4 axle design. It was the only machine on the market that provided the capability to lift flat racks at a capacity of 35 tonne, but still evenly spread the load weight enough so the machine won't break up our facilities foundations.'
'Wire Industries has grown to become one of Australia's leading suppliers of reinforcing steel products and services, and as our business grows we are concerned with acquiring the right machinery that not only allows us to maximise our space, but is also cost effective to operate'.
'During our research we found most container handlers on the market only have two axles, which places double the load on the yard, and even though some brands claim that placing dual wheels on each corner will lessen the damage - this is not the case". said Mark Ranie, Manager of Wire Industries QLD.
"The 2T allows us to load/secure stock on transiflats at ground level, which is far safer & quicker than loading trailers, and we have eliminated our need for sideloader pickups which has saved us money on every delivery. It also gives us the flexibility to bring stock inside out of the weather, and separate our transport from our operations as we can have our transit load waiting in advance reducing our truck waiting times", said Mark Ranie Manager, Wire Industries, QLD.
Tom Schults Managing Director of Mobicon Systems said; "The 2T's capability of lowering its height to just under 4 meters, allowing it to move under most awnings, and also being able to operate in a space as small as a five meter wide laneway, makes it perfect for the type of operation that Wire Industries is running'. "Coupled with the fact that the average industrial yard in Australia is generally made out of 200mm concrete with one layer of steel reinforcement, or the equivalent bitumen (which is the case at Wire Industries), basically means only a 4 axle Mini Straddle Carrier such as the 2T, is suitable for this surface as its four axles ensures the load is spread evenly enough not to crack or damage the foundation saving our clients the cost of a yard resurface'.
For Further Information please contact: Jesse Schultz - Business Development Manager
email / +61 (0) 427 57 57 22
About Mobicon Mini Straddle Carriers
Established in 1994, Mobicon Systems designs and manufactures Mini Straddle Carriers that provide cost effective, quick and reliable container handling solutions.
Suitable for a wide variety of terrains, the Mobicon's unique 4 axle design is the only Mini Straddle Carrier on the market today recognised by civil engineers not to damage the average yard.
Mobicon Machines are used all over the globe in industries such as Defence Forces, Customs, Ports, Logistics Companies, Mining and Import/Export operations who require fast and efficient container handling operations.
Mobicon Mini Straddle Carriers are a safer, and more cost effective solution than forklifts or side loaders and are durable, easy to use, and provide superior maneuverability.
Mobicons most popular models include the TF2 which can stack one on one, and uses an Elme spreader to lift the containers meaning the driver does not have to exit the cabin. Plus the 2T which can go anywhere including under awnings and be used in small warehouse conditions.
Mobicon Systems
P: +61 7 3811 5049
E: send an email
W: www.mobiconsystems.com
ShopFront Facebook Linked In Twitter
Get in touch with Mobicon Systems
Mobicon Systems
+61 (0)... Show
PO Box 7063
Brendale QLD Australia 4500
Mobicon Systems
