KEYSHOCK Impact Abuse Alarm for Equipment
- 11 Aug 2016 ( #782 )
KEYTROLLER'S KEYSHOCK is a simple extremely rugged, very affordable, stand-alone impact alarm and monitoring system that is used on variety of vehicle and machine applications. The device is a simple and inexpensive way to make abusive drivers accountable for reckless driving and damage. It is designed to fit easily to any make or model forklift or vehicle, electric, diesel, LPG or gasoline powered.
HOW IT WORKS:
  • Designed to act as stand-alone impact abuse module.
  • Provides indication if equipment or machine has been subjected to abusive impacts.
  • Three axis accelerometer X (front/back) Y (side/side) Z (up/down). Each can be enabled/disabled.
  • Can be set to ignore very short (ms) duration forces to "soften" set-point and reduce false alarms.
  • Two alarm outputs; alarms when impact deceleration is in excess of trigger threshold set-point.
  • Alarm software settings can be set to "latch" (stay on), pulse, output for 6 seconds, pulse for 100ms.
  • When set to "latch" (stay on) it can trigger flashing siren alarm vehicle has been involved in impact!
  • When set to "latch" (stay on) then a key reset from supervisor is required (optional key switch).
  • "Latch" can also trigger low speed on SPEED-SAVER top speed controller or relay for shut down.
  • Removing battery input power will NOT reset the device-when power is supplied, alarm sounds.
  • Because it has 3 axis, module can be fitted horizontally or vertically (see vertical picture below).
  • Logs number of impact abuse events
  • FREE programming software connects via USB to laptop.
TECHNICAL SPECIFICATIONS
  • Voltage 8 - 60vdc
  • Current standby <10mA
  • Module IP rating 67
  • Output1 Current rating 500mA
  • Output2 Current rating 500mA
  • Case aluminum, black powder coated
  • Lead length 6ft (2.0mtrs) nominal
PROGRAMMED VIA USB PORT - PC SOFTWARE IS FREE!
  1. Password protected log in for settings.
  2. Enable/disable any of X-Y-Z axis.
  3. Set sensitivity for each axis independently.
  4. Set "ignore" time for each axis (ms).
  5. Set style for each output independently.
  6. View current output of each axis (helpful in setting accurate threshold
INSTALLATION:
KEYSHOCKS small profile 95mm x 58mm x 32mm (3.7" X 2.3" X 1.2") fits easily to many mounting locations on a vehicle and the device will fit to any 12, 24, 36 or 48VDC power supplies. The unit consists of 2 components:
1. A completely weather sealed heavy duty cast aluminum module.
2. Wiring harness. All electrical connections are made at this harness.
EVENT LOGGING:
Counter in software shows how many impact events over threshold settings have occurred.
PROGRAMMING:
The user connects to the device via a USB connection where the sensitivity thresholds are set. He can also set the two outputs to "latch" (stay on), pulse, output for 6 seconds, pulse for 100ms. When set to "latch" stay on the user must have the optional keyswitch installed that the supervisor uses to reset the unit (turn off the alarm and/or re-enable the vehicle ignition circuit)
AFFORDABLE:
Designed to be sold by an equipment dealer for under $500. Equipment dealers are invited to contact KEYTROLLER for attractive dealer pricing.
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message, click here to visit the KEYTROLLER ShopFront
