Let's start at the very beginning
Wayne Chornohus -
Safety First
- 24 Mar 2016 ( #762 )
Wayne Chornohus started repairing forklifts in Canada about 50 years ago and since then has held various managerial positions with independents and dealerships alike. Eventually, he started a unique operator training company, unique in technical depth and accuracy. A decade later, he formally retired and now teaches English in foreign climes and does some technical consulting.
In my last column, I addressed how mundane much of the training rhetoric has become. In this post and future contributions, I would like to examine some of the hardcore repetitious safety statements and provide perspective.
"Alice: How long is forever? White Rabbit: Sometimes, just one second." - Lewis Carroll
In one second or less, a life can be changed forever. Before starting work, it is always recommended that the operator does a pre-shift inspection. But what is a pre-shift inspection? Is the operator qualified to do an inspection? Most companies provide a list to help the operator conduct the inspection in an orderly fashion. In reality, most operators just check off each item and go to work.
Unfortunately, many trainers often give items on the list a superficial explanation. But if we give the operator some interesting and relevant education, he just might realise how important the check is.
Let's take one item to review: Check forks. That is, check for wear and tear and any abnormalities. Wear at the heel of the fork reduces the fork capacity tremendously. Even if the wear is as little as 10%, the fork capacity is compromised and it is recommended that set of forks be replaced.
Okay, we have checked the fork and latches, but have we given any thought to the cause of wear at the heel? Do you know that if a forklift is maintained properly, the forks will last forever as far as heel wear goes? Thus, financial as well as safety benefits to a good inspection!
To check if maintenance has been done properly, set the mast in the vertical position with the forklift on a flat and level surface. Lower the forks fully. If a fork touches the ground, the chains require adjustment. Once again, the forks should not touch the surface or floor in the fully lowered position with the mast vertical on a SDCB forklift. Sometimes, the tyres will require replacement, especially on a cushion tyre forklift.
Adjusting the chains is easy but dangerous; only experienced forklift mechanics should perform the adjustment. The technician should also check for chain wear at the same time. Chains will stretch a surprising amount from new.
So what if a fork breaks? A standard ITA Class 2 fork can weigh more than the operator. If a fork breaks, it is usually under load and could fly through the air, causing a "forever" injury.
If there are any pre-shift inspection items that you would like to know more about, please contact me here .
Also Read:
Tejal Ranjan
3 minute read
How positive friction prevents forklift accidents before they happen
Stuart Taylor
3 minute read
How positive friction prevents forklift accidents before they happen Safety First - 27 Nov 2025 (#1258) Stuart Taylor is managing director of Mentor FLT Training Limited looks at ways positive friction can be used to help prevent forklift accidents from happening
How advanced relay contact design transforms forklift reliability
Carlos Mendes
3 minute read
How advanced relay contact design transforms forklift reliability Your Focus - 20 Nov 2025 (#1257) Carlos Mendes is a product manager for switching at Durakool, working closely with engineers and buyers to bridge the gap between application and specification.
VETTER Industrie GmbH
