New Lift Truck Mast Extension on CeMAT
- 22 May 2014 ( #668 )
This unique Mast Height Extension range is designed to improve space utilization and/or add versatility by increasing the lift height of your current forklift truck without changing the mast. This is especially useful when the existing mast does not comply with the required lift height. The Mast Height Extension easily mounts to most any type of lift truck allowing the truck to handle extra pallets at a higher level without extending the load center.
Features
  • Excellent visibility.
  • Minimum lost load thickness.
  • All cylinders are protected.
  • Original lift truck forks can be used.
  • Lift truck forks can be moved sideways.
  • No need to exchange the existing mast.
  • Only one extra hydraulic function required.
Increase maximum lift height
The Mast Height Extension is designed to increase the lifting height of an existing lift truck mast. By adding the Mast Height Extension, users can often increase their rack beam height and maximize storage density without the need to change the mast or buy a new lift truck. Similarly the Mast Height Extension can be used to improve under-door clearance whilst maintaining greatest possible lift height.
Mast Height Extensions...add extra lift to existing forklifts!
More innovations at CeMAT 2014
Together with German manufacturer, Griptech GmbH, MSE-FORKS will be present at CeMAT 2014. More innovative products will also be on display such as the Shift2End, (S2E). This forklift attachment is an innovative side-shifting fork positioner with telescopic forks designed for handling variable pallet widths and lengths. It can shift telescopic forks or manual extendable forks all the way to either side without protruding outside the fork carriage. This makes container and trailer off-loading quicker and easier especially when dealing with various load sizes.
Another unique forklift attachment displayed on the CeMAT 2014 is the RollerForks Push/Pull. By using the unique RollerForks® Push-Pull attachment combo, it is now possible to load and unload containers and/or trailers with loads stacked on top of one another faster than ever before. RollerForks® are ideal for lifting loads stacked directly on the floor because the floor acts as a fixed reference point for turning the rollers. However, if loads are not stacked directly on the floor, e.g. two-high, then the push-pull mechanism can be used. As soon as the load has been manoeuvred onto the RollerForks®, it can be easily transferred onto a a pallet using the RollerForks®.
Want to know more? Visit us during the CeMAT in Hannover (hall 26, stand F10) or visit our website www.mse-forks.com.
MSE-Forks is based in The Netherlands, with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company leads the world market as the largest producer of hydraulic lift truck forks, more commonly known as "KOOI-REACHFORKS®"; however, MSE-Forks also produces a wide range of innovative materials handling solutions including: Height Shift Systems, (vertical lift forks), telescopic Jib Crane attachments and booms as well as a complete range of palletless handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers and other products (www.slip-sheet-attachments.com). The latest MSE-Forks product to be introduced to the market is the patented FLEX-OPS, a safety enhancement for forklift trucks that helps prevent tip over accidents, www.mse-ops.com.
MSE Forks
St. Jacobiparochie, Netherlands
Telephone: +31 518 492929
email: send us a message
Website: www.mse-forks.com
For more company and product information visit the MSE Forks ShopFront
