Operating Safely at Height with Order Pickers
Steve Reynolds -
Your Focus
- 24 Apr 2014 ( #664 )
Steve Reynolds
Steve Reynolds
Steve Reynolds is the Victorian Sales Manager and has worked at Adaptalift Hyster since April 2010, having previously worked for Hyster since 2006 prior to the acquisition. As well as managing a successful sales team in Victoria, Steve deals with big truck customers, assisting them in making the right choice for their particular applications.
1. Operating at more than 1 metre from the ground
If operating at more than 1 metre from the ground, the machine must be lowered to 600mm or lower before moving forward or reversing to the next location. This is important as the stability of the load at height may be affected when moving.
The machine must then come to a stop before being raised to the desired working height again. All order pickers are fitted with limit switches to prevent them from driving at height. These switches must never be tampered with.
2. Safe travel height
The machine must come to a stop before being raised
The order picker must be lowered to a safe travel height before turning a corner or exiting an aisle. A safe travel height is clear of the ground but below axle height. This will ensure the order picker does not tip over.
3. Wearing a harness
When operating an order picker, a harness must be worn at all times and, when moving, the handrail must be closed on the platform. This will prevent falls from the order picker.
4. Traffic management
Traffic management is another important aspect of safety when operating an order picker. Making people aware of areas of operation is the easiest way to avoid risks and this can be done by:
* Posting signs
* Erecting barriers
* Using a flag person to control the flow of traffic
5. Potential hazards
It is extremely important to ensure all work areas are free of potential hazards. The safest path to take when moving a load and operating the order picker should always be considered in order to prevent any accidents, injury to other personnel or damage to machinery, equipment and stock.
What to watch out for in the work area:
* What hazards are present?
* Where will you be required to stop?
* Where should you slow down?
* Where should you sound your horn?
* Will you need to reverse?
* Is ventilation adequate?
* Is there adequate lighting?
* Do you have room to move?
* What is a safe speed?
* Is the ground surface suitable?
* What clearance do you have?
Are these precautions carried out in your warehouse?
Also Read:
Manual or automated material handling: finding the right balance
Diana Davoyan
3 minute read
Manual or automated material handling: finding the right balance Your Focus - 6 Nov 2025 (#1255) Diana Davoyan is a marketing professional and copywriter in the global robotics sector, with extensive experience in industrial and warehouse robotics. Here she looks at striking the right balance between manual and autaomted MH operations.
How software platforms and AI are changing work for material handlers
Buddy Bockweg
4 minute read
How software platforms and AI are changing work for material handlers Your Focus - 23 Oct 2025 (#1253) Buddy Bockweg is the CEO and co-founder of Vsimple, the AI Operations Platform. Here he loosk at how sotfware platforms and AI are changing work for material handlers.
Murray Cox
2 minute read
