RUYI CBD20K(D) Electric Pallet Truck
- 6 Mar 2014 ( #657 )
The super-light walkie-type CBD20K(D) (2,000kg) with small turning radius and low profile chassis is widely used in narrow space like small supermarkets and workshops.
Advantages:
SAFETY AND PRODUCTIVITY:
  • Advanced AC control system eliminates the motor brushes and directional contactors, which reduces maintenance requirements. Intelligentized regenerative brake system increases overall truck performance by reducing battery charge intervals.
  • Side-way battery with roll-out system makes it very convenient to replace batteries.
  • Emergency reversing device.
  • Built-in pressure relief valve protects the truck from overloads.
  • Long handle tube gives flexible and labour-saving operation.
  • Emergency power disconnect.
  • Low speed switch in the handle.
  • Stepless speed control.
STRUCTURAL:
  • Vertical driving wheel creates small turning radius. The structure is water-proof and dust-proof.
  • The riser axle, located at the highest point of forks, is protected from constant contact from uneven floors. Pull rod design protects the rod from bending.
  • Spring-loaded castors improve lateral stability on uneven floors and enhance truck performance and service life.
  • One-piece, heavy-gauge steel is used for maximum strength of the forks.
SERVICEABILITY:
  • Low battery protection setting prolongs the battery use time.
  • CANbus technology reduces wiring complexity and increases reliability.
  • All pivot points have grease fittings and serviceable bushings, reducing component wear and extending component life.
Drive System:
  • Multi-function indicator and hour meter
  • Option: swing-out battery tray
Main specifications:
Click to read more about the super-light walkie-type CBD20K(D)
Ningbo Ruyi Joint Stock Co. Ltd. will attend the following International Trade Shows from March to May in 2014.
Name of Exhibition: Cologne International Hardware Fair
Cologne International Exhibition
Date: March 9-12, 2014
Booth No. 2.1-C34, 3.1-F87
Name of Exhibition: MODEX 2014
Georgia World Congress
Date: March 17-20, 2014
Booth No. 7436
Name of Exhibition: CeMAT 2014
Hannover Exhibition Center,
Date: May 19-23, 2014
Booth No. 25-F09
Mr. Chu Jiang
Vice President
NINGBO RUYI JOINT STOCK CO., LTD.
Tel: +86-571-87153626, 87153634
Fax: + 86-571-87153628, 87153638
E-mail: sales@xilin.com/ ruyi@xilin.com
Website : www.xilin.com
Click here to view Ruyi's Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
