Ruyi boosts Reach Truck range
- 10 Jan 2013 ( #598 )
Click image to enlarge
In 2013 Ningbo Ruyi Joint Stock Co. Ltd. continues to innovate with its new Fork Reach Truck with capacities from 1,200kg to 2,000kg and widely used in narrow-aisle warehouses.
CQDH15A /CQDH20A (1,200kg /1,500kg/2,000kg)
Electric Fork Reach Stacker
Advantages:
  • Compact structure makes it easy to use in narrow aisles.
  • Stepless speed control, smooth/controllable speed.
  • Reach distance up to 500mm.
  • Fork can be tilted forward 3 degrees or backward 5 degrees.
  • Intelligentized regenerative brake system.
Options:
  • Side shift,
  • Full free lifting mast,
  • EPS (with vertical driving wheel)
  • Double scissors fork
CQDH15C (1,500kg )
Electric Fork Reach Truck
Advantages:
SAFETY AND STABILITY
  • Advanced AC control system eliminates motor brushes and directional contactor, which reduces maintenance requirements.
  • Stepless speed controls
  • Intelligentized regenerative brake system: increase overall truck performance by decreasing battery charge intervals.
  • Equipped with adjustable hand-rest, adapted to different operator.
  • Multi-function display: battery status, hour meter, fault indicator, etc.
  • Two-side battery access with roll-out system is very convenient for battery replacement.
  • Damping cushion for low-noise operation.
  • Built-in pressure relief valve protects the trucks from overload.
  • Emergency power disconnect.
STRUCTURAL
  • Low centre of gravity ensures stable operation.
  • Vertical driving wheel has a small turning radius and is easy to maintain.
  • The motor structure is water-proof and dust-proof.
  • The Scissor Reach Forks are operated by electric controller, which makes operation stable and no impact.
SERVICEABILITY
  • Low battery protection setting prolongs the battery use time.
  • CANbus technology reduces wiring complexity and increase reliability.
  • All pivot points have grease fitting and serviceable bushing, reducing component wear and extending component life.
  • The back cover is easy to open for maintenance and adjustment of valves, oil tube and electronic parts.
Options:
  • Full free lift masts
  • Side shift
For further information regarding any model in RUYI's range, please
contact:
Mr. Chu Jiang
Vice President
NINGBO RUYI JOINT STOCK CO., LTD.
Tel: +86-571-87153626, 87153634
Fax: + 86-571-87153628, 87153638
E-mail: sales@xilin.com/ ruyi@xilin.com
Website : www.xilin.com
Click here to view Ruyi's Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
