NEW Warrior 5000Kg Pedestrian Controlled Tow Tractor
- 7 Jun 2012 ( #568 )
The new WARRIOR ATT50, - Pedestrian Controlled Tow Tractor. Click for larger image.
European Handling has introduced a brand new model pedestrian controlled tow tractor suitable for most industrial applications. The WARRIOR ATT50 is based around the company's top selling pedestrian operated counterbalanced forklift truck and has some impressive attributes. Able to pull 5000kg on the flat, the tiny tug has enough grunt to pull 3000Kg up a 10% incline.
Gone are the days when the operator has to "hang on" with his body weight to turn the truck as this tug has the proven Zapi power assisted steering using less than 1kg of effort.
Totally programmable characteristics allow custom acceleration, manageable speed control and prevents wheel spin. The ATT50 is heavy duty but only measures 1406mm long by 978mm wide. Power comes from a 240A/h 24v TAB traction battery which gives greater shift usage due to the AC spec.
A demo model is available.
For further details of the truck models contact Andy Williams of European Handling Equipment Ltd 0044 1384 423330
Andy Williams
Contact
t: 0044 1384 423330
e: andy@european-handling.com
w: www.europeanhandling.com
