ROLLER PUSH PULL Equipment (patent pending)
- 13 Oct 2011 ( #535 )
MSE-FORKS is launching per December 1st 2011 a new concept in push pull forks. The ROLLER PUSH-PULL is a push pull made up of two separate units. Both parts (left and right) are extended hydraulically using the Equalizer System principle. The push pull can be fitted with regular fork plates or patented ROLLERFORKS®.
ROLLER PUSH-PULL benefits:
  • faster than existing push-pull systems
  • good line of sight between separate units
  • independant lateral adjustment for even load distribution
  • synchronized unit extension and retraction
  • single unit for small and light loads.
  • faceplate adaptor available.
  • improved slipsheet engagement (folding forks)
  • ideal for stacked goods seperated with slipsheets.
MSE-FORKS opts for ROLL PUSH PULL [ Rollerforks @ YouTube ]
Saving Time with ROLLER PUSH-PULL
Using the unique ROLLER PUSH-PULL combo, it is now possible to load and unload containers and/or trailers with loads stacked on top of one another faster than ever before. ROLLERFORKS® are ideal for lifting loads stacked directly on the floor because the floor acts as a fixed reference point for turning the rollers. If loads are not stacked directly on the floor, e.g. two-high, then the push pull mechanism can be used. As soon as the load has been manoeuvred onto the ROLLERFORKS®, it can be easily transferred onto an in-house pallet using the ROLLERFORKS®. This method saves a lot of time because the push pull mechanism does not have to be extended or retracted.
The ROLLER PUSH-PULL is available per December 1st 2011.
To see more great product videos visit the ROLLERFORKS YouTube channel
MSE Forks
email: info@mse-forks.com
Website: www.mse-forks.com
Telephone: +31 518 492929
St. Jacobiparochie, Netherlands
For more company and product information visit the MSE Forks ShopFront
