Moneysaving Forklift Battery Recovery Technology
- 18 Sep 2008 ( #378 )
STOP !!! Don't replace your forklift battery or "bad" cells ... use a CellSAVER to return a weak cell to normal operating voltage.
ENERGYTECH (Australia) and FORKLIFT BATTERY TECHNOLOGY (USA) are pleased to release a new product to assist in the restoration of problem cells in forklift traction batteries.
As a traction/Solar/UPS/ lead acid battery ages one or more individual cells become weaker and have low voltage. One key reason for this occurrence is the inability of a multi cell charger to charge each individual cell to the optimum level. When a battery (comprised of several cells) is being charged, the charger is monitoring the "Overall" voltage and when the charger "sees" correct terminal voltage it decides the charge is over.
Unfortunately some cells have a greater resistance to accepting a charge and so during charge the healthier cells will be overcharged while weaker cells are undercharged. Thus when the charger completes its cycle the weaker cells have not had sufficient time to get to a fully charged state. This failure of a cell to fully charge means a weak cell is repeatedly undercharged and cell voltage will continue to decline.
With the new CellSAVER these charge starved cells are able to be individually charged to recover "lost" voltage. To return the cell to good State of Health (SOH) this individual cell charging may have to be undertaken several times and is best undertaken in conjunction with a process to desulphate the cell. (See our BatterySAVER system). When you desulphate a cell AND charge the cell fully we find few low voltage cells actually need replacing!!
Model:CellSAVER - ET-0280BM
Function:Voltage Recovery* of an Individual 2V CELL
In Traction Battery, Solar Bank, UPS etc
Weight:3.0KG
Operating Supply Voltage:110/220V switch able
Charging Voltage:2V - 2.58V
Charge Type:Constant Current in bulk, Taper in equalise and float
Charging Current:Automatically set (up to 80A)..... OR manually adjustable 10-80A
Charging Modes:Bulk 0.05-2.58V, Equalise 2.58, Float 2.3V.
Charge Type:Full Automatic Charge...(set and forget, auto float when cell fully charged )
AND manually adjustable amperage output for customised charge control
Digital Display:Switched for Voltage or Amperage readout
Charge Curve:
Adjustable Output.
Cell capacity varies dramatically depending on the system design, working environment and potential A/hr load demand. The CellSAVER's adjustable output is to allow for customizing the charge for different capacity cells. Always consult the battery manufacturers specifications BEFORE undertaking any individual cell charging. Calculate and adjust CellSAVER amperage for a charge appropriate to the CELL size and capacity.
Over Voltage Cells
Some cells go over voltage when charging due to high resistance to charge with severe sulphation and weak electrolyte. We find these can often be fixed to with the CellSAVER if you desulphated with the BatterySAVER for a few hours .... and then also simultaneously connect the CellSAVER to the weak cell. Over voltage cells generally respond quicker/better with the addition of 150-200ml of our CellFIX solution. If your desulphation process is working well the charge voltage should soon drop to normal level if the cell is going to "fix". If there is little or no voltage reduction in the first 30 to 45 minutes it is unlikely you will be able to fix the cell.
All others say REPLACE.... We say REJUVENATE!
WHO WE ARE
Energytech and Forklift Battery Technologies are sister companies developing innovative and leading edge technologies to recover lost capacity and extend the life of large expensive storage and traction batteries. If you have expensive batteries we can save you thousands!! We rejuvenate old tired (and even decommissioned) batteries, protect current battery investment, cut battery operation costs AND extend battery life. Please phone, fax or email us a detailed description of your batteries and the problems you may be experiencing so we can provide assistance.
Energytech Brisbane Australia
cellsaver@energytech.com.au
0406 680 909
