Meclift Variable Reach Trucks & Side Reach Stackers
- 26 May 2005 ( #210 )
Meclift specializes in the design and marketing of innovative materials handling equipment for ports and industry. Our objective is to globally provide cargo handling industries with the latest technology for improved productivity and cost efficiency.
Due to their compact design, the Meclift Variable Reach Trucks offer new possibilities for loading and unloading containers. They can be driven into standard containers, and their reach feature enables them to operate in conditions that would be impossible for straight-mast trucks. For example, steel coils are loaded for container transportation using a 16-tonne machine, which can push up to 25-tonne loads into a container. Our 30-tonne variable reach truck has proven its excellence in stone handling both inside ships and on the quayside.
Side Reach Trucks
The versatile Side Reach Stacker replaces the conventional method of using many different machines to handle and carry loads.
The Side Reach Stacker handles and carries freight containers and other loads in a longitudinal direction enabling a higher transport speed and more efficient performance. Thanks to its low centre of gravity the ML 5016SR can handle loads up to 42.5 tonnes under the toplift spreader at a load distance of 1.6 metres, and 30.5 tonnes without using support legs.
The Side Reach Stacker can lift a container, two coupled containers or heavy loads on its frame, move the load at a speed of 30 km/h, as well as unload and stack containers up to four high.
Agents wanted
Meclift Ltd is looking for agents worldwide for distribution of innovative cargo handling equipment.
The Meclift products include variable reach trucks and side reach stackers for handling containers and heavy loads in harbours, paper mills, steel mills and railways. Lift capacities range from 6 to 50 tonnes.
If you are interested in promoting these world-class products, forward your company name, website, contact person, phone, fax and e-mail address to sales@meclift.fi
All enquiries will be treated confidentially.
See our website: www.meclift.fi.
