Mast Height Extensions add extra lift to existing forklifts!
- 30 Jan 2014 ( #652 )
As a warehouse manager, you are always looking for the most efficient way to use available storage space. Especially, now the economy is slowly recovering it might seem your warehouse is getting too small to handle your increasing daily flow of orders. For many companies, a warehouse expansion or off-site storage is simply too much of an investment risk during these uncertain times.
A much cheaper and far more effective solution is to simply make better use of your current space. Take a look at your warehouse. Even if the aisles and racking are as narrow as possible for current equipment, you must ask, " am I utilizing all available vertical space? "
The solution for increased storage can be as simple as adding more levels to your rack system.
You may think this means you will have to replace all your existing forklift trucks to reach higher levels. It doesn't! Fortunately, the new Mast Height Extension (MHE) attachment will allow you to add additional lift height to your current forklift trucks without changing the mast, (upright).
The Mast Height Extension, (MHE), is an attachment designed to enhance the lift height on fork lift trucks. It can provide additional lift height ranging from 100 mm up to 500 mm with 2000 kg. capacity. ( 4" to 20" and it is available with capacities over 4,400 lbs.)
By adding a Mast Height Extension to your existing lift truck you can increase the maximum height of your rack storage system without the need to change the mast to a longer version or buy a new lift truck.
The MHE can also be used to improve under-door clearance issues allowing a truck to pass through whilst maintaining the ability to reach higher levels.
The MHE mounts to a standard FEM ( ITA) type fork carriage and it allows the use of existing lift truck forks with full adjustability, (fork spread), within the MHE carriage frame. The system simply requires a single hydraulic function and its sleek design provides excellent visibility with minimum lost load thickness. It's even available with quick-change mounting hooks for applications which only require occasional use or movement from one truck to another.
Mast Height Extensions: add extra lift to existing forklifts!
To learn more: www.telescopicforks.com
Booth #7131 during MODEX 2014 in Atlanta.
Check us out on Facebook
, later this week we will post an EXCLUSIVE OFFER for visitors of the MODEX 2014.
MSE-FORKS is based in The Netherlands with a wholly owned subsidiary in the USA and distributors in more than 60 countries worldwide. The company leads the world market as the largest producer of hydraulic lift truck forks more commonly known as "KOOI-REACHFORKS®" however, MSE-Forks also produces a wide range of other innovative material handling solutions including; telescopic Jib Crane attachments and booms as well as a complete range of pallet-less handling solutions such as ROLLERFORKS®, Push-Pulls, Stationary Pallet Changers and more, www.slip-sheet-attachments.com. The latest MSE-FORKS product to be introduced to the market is the patented FLEX-OPS, a safety enhancement for forklift trucks that helps prevent tip over accidents, www.mse-ops.com.
For more company and product information, Click to visit the ShopFront
