KEYTROLLER’S LIFT-N-WEIGH
- 2 Aug 2018 ( #883 )
LIFT-N-WEIGH Mk4 Weight Indicator uses the pressure in the lift circuit, coupled with a pressure transducer, to output a signal to the digital display unit. This method gives you an extremely accurate indication of the weight with an accuracy of 2% of the capacity of the forklift. KEYTROLLER'S LIFT-N-WEIGH is very popular with forklift dealers looking for a weatherproof, rugged scale that is economical.
LIFT-N-WEIGH is dealer priced at under $775 and sold to an end user for under $995; making it very affordable for any lift truck application. The scale fits to all makes and models of forklift trucks. The trouble-free, easy-to-read design is fast and easy to install. With its pressure averaging technology, the LIFT-N-WEIGH gives drivers the confidence they need when handling heavy loads - overload warning is standard.
MK4 Kit includes:
  1. LCD screen with adjustable mounting bracket
  2. Hydraulic pressure sensor and fitting kit
Features:
  • LED readout in Lbs or Kgs - brightly lit for all types of environments.
  • Bright RED LED indicates load as a 'live' weight.
  • Accuracy +/- 2% of truck capacity (within 100# on a 5000# capacity forklift).
  • Totalization: Add additional loads (cumulative) OR subtract last load.
  • Quick and easy installation.
  • Proven technology in a robust waterproof enclosure sealed to IP67 for outdoor usage.
  • Unique bracket enables installation of the instrument in any position for easy viewing.
Benefits:
  • Increases loading safety in yard and/or warehouse.
  • Value-adding system with minimal investment.
  • Allows accurate and even loading of storage and vehicles.
  • Enables check-weighing of incoming and outgoing goods.
  • Hydraulic scales can not be damaged in tough applications.
  • Increases vehicle efficiency.
  • Maintains accuracy; requires no periodic re-calibration or servicing.
  • Promotes best operator use.
  • Maintains lifting capacity and driver visibility.
  • Automatic and manual zero correction.
  • Gross / net weighing.
  • Automatic tare and manual tare weight entry.
  • Total loads with sequential numbers.
  • Error message in display.
  • Automatic switch off after two hours of non-use.
  • Overload protection 300%.
Specifications:
  • Operating Voltage: 10 - 30 Vdc
  • Sensor Range: 0 - 250bar
  • Temperature Range: -20 to +40°C operating
  • Accuracy: +/- 2% of fork truck capacity
  • Warranty: 1 year
  • Enclosure protection: Instrument unit IP67 Full RFI/EMI protection
Dealer cost: $750
End user price: $995
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: send a message, visit the KEYTROLLER ShopFront
About Keytroller, LLC
Founded in 1988, Keytroller, LLC designs, manufactures and supplies a full line of electronic safety devices designed for forklifts, construction equipment, aerial lifts, personal carriers, boats, and vehicles. Their solutions include: RFID or PIN code access-monitoring systems, electronic checklist automation, impact and speed sensing, speed and directional shift controls, anti-theft wireless relay systems, digital video DVR recorders with GPS, wireless camera viewing systems, forklift spotlight warning LED, cellular and Wi-Fi hour meters, and high accuracy hydraulic weigh scales. Keytroller is headquartered in Tampa, Florida and enjoys relationships with over 500 North American equipment dealers (aftermarket) many OEM vehicle manufacturers (installed as original equipment) and importers in England, Europe, Australia, South America and Southeast Asia.www.keytroller.com for more information.
