Introducing Ningbo Ruyi FGY LPG series Dual Fuel Forklift
- 26 Aug 2010 ( #476 )
Ningbo Ruyi FGY LPG series Dual Fuel Forklift offers capacities from 1.5 ton to 3.5 ton, incorporating advanced international technology from TCM, with easy maintenance, superior ergonomics and advanced dependability, safety and durability, enhanced productivity and lower operating costs. This is really the most stable, comfortable, economical and safest choice.
RUYI always focuses on innovative and advanced philosophy in forklift design to provide superior quality products with comfort and customisable performance.
This model boasts the following advantages:
  • Focus on green energy to protect environment, with low emissions and low noise to conform to new Machinery Directive 2006/42/EC.
  • Offers various engine types such as CHINESE BY491 and NISSAN K21/K25, BRC converter made in ITALY and NIKKI made in JAPAN. All with superior power and economic fuel consumption.
  • Advanced multifunction LCD/digital display, with digital service hour meter, battery discharge indicator plus lift cut-out, clock, error code and warning displays which provide fast and accurate Monitoring truck status.
  • Wide view mast, clear visibility.
  • Air intake system: Air intake system mounted on the pillars of overhead guard, reduce the noise.
  • Complete Security Protection System: neutral safety protection switch, reverse warning light, wide steel non-slip step.
  • Engine protection lock: prevents starting the engine while engine is running. Eliminates the gear wheel damage unexpected.
  • The cylinder offers new design with dual safety system: lowering safety valve and lowering limited valve: effective prevent cylinder descending suddenly should the hydraulic system unexpectedly break.
  • Neutral safety start system: The electric F/R lever has to be in the neutral position before the engine can be started.
  • An intelligent sensor and buffer monitoring system offers safety check valve to absorb the mast drop speed automatically to avoid crashed the floor and damage goods.
  • The Parking brake lever inter-locks with the electric F/R lever, enabling the truck to automatically brake when the electric lever in neutral position.
  • Low gravity design ensure stable and safety during transfer and steering.
  • Easy to operate LPG and gas exchange switch.
  • All-new swing-out & drop-down tank bracket. The LPG tank can swing out 180 degrees and drops down approximately 75 degrees for effortless removal and installation.
If you are interested in these models or other products, or if you have any questions, please feel free to contact us:
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
