Hyster's Dynamic Stability SystemHyster will be adding a new safety system, Dynamic Stability System (DSS), as standard on all H40-70A models in the recently launched Hyster A Series.
“Safety is critical in materials handling. Fast-paced environments and demanding productivity targets are just another day on the job for forklift operators,” says Jimmy Anderson, Hyster product manager. “That’s why DSS is engineered to give operators real-time stability support they can count on and learn from. The system is also designed for managers, offering insight to how forklifts are being operated, particularly when integrated with the Hyster Tracker option, which is a real differentiator. DSS does all of this without requiring the additional maintenance and upkeep some competitive systems demand.”
All DSS sensors are completely maintenance-free and continually monitor forklift performance such as lift height, hydraulic load, mast tilt, truck speed and steer angle. When the system detects the lift truck exceeding designated stability thresholds, it automatically intervenes with measures to support stable travel. Four different subsystems help to smoothly decelerate the forklift when traveling around corners and in turns, and to limit truck speed, tilt speed and tilt range when carrying elevated loads.
The operator remains in command of the equipment and receives performance reduction feedback, visual indicators and audible alerts to help reinforce the best practices established in their training. Integration with Hyster Tracker telemetry monitoring is also available to help supervisors access greater visibility into operator performance through real-time updates each time a DSS function is triggered.
