Explore HAWKER LifePlus® Xtreme: The Ultimate Outdoor Charging Solution
- 8 May 2025 ( #1229 )
4 min read
Outdoor operations have always faced a power dilemma: reliability versus environmental durability. When equipment must function in rain, snow, dust, or extreme temperatures, standard charging solutions often force compromises that impact productivity and maintenance costs. For businesses operating Ground Support Equipment (GSE), managing produce harvesting machinery, or running outdoor warehousing, power interruptions are inconvenient at best — and costly at worst.
That’s where the HAWKER LifePlus® Xtreme comes in. This fully IP54-rated outdoor charger is designed to withstand dust, water spray, and extreme conditions while delivering reliable, efficient power. As the leading industrial battery charger, it features advanced communication features, a modular design, and compatibility with multiple battery types — keeping your critical equipment powered and ready for action.
Built for the Elements: Understanding the IP54 Advantage
The fully IP54-rated HAWKER LifePlus® Xtreme offers superior protection against environmental factors that typically compromise standard charging equipment.
But what exactly does IP54 mean for your operations?
This ingress protection rating indicates that the electrical enclosure is effectively protected from:
  • Limited dust ingress that could otherwise damage internal components
  • Water spray from any direction, ensuring functionality even during unexpected weather changes
For operations that can’t stop when the weather turns, this level of protection translates directly to improved uptime and reduced maintenance costs.
Versatility Meets Performance
What truly sets the HAWKER LifePlus® Xtreme apart is its remarkable versatility across applications and battery technologies. The charger features:
  • Universal Battery Compatibility: Charges all battery types, including traditional flooded lead acid batteries (HAWKER Energy-Plus™ and HAWKER Water Less®), advanced HAWKER FLEX® TPPL battery (Thin Plate Pure Lead) technology, and HAWKER FLEX® Li3 Lithium battery technology.
  • Intelligent Communication: Full communication capabilities with batteries via Battery Boss WC 4 (BWWC4) and CAN communication enables fast charging of HAWKER FLEX® Li3 lithium or HAWKER FLEX® TPPL batteries, optimizing both charging times and battery lifespan.
  • Modular Design: Modularity allows for flexible capacity from 3.5kW modules (1 to 6) offering configurations of 7kW, 14kW, and up to 21kW, tailoring the system to your specific operational requirements.
Smart Technology for Modern Operations
Modern industrial equipment requires intelligent charging solutions that integrate with operational systems. The HAWKER LifePlus® Xtreme fast charge battery charger delivers on this demand, featuring:
  • Mobile Connectivity: Setup and data downloading through a free mobile app with Bluetooth connectivity lets your team monitor charging status remotely and make adjustments as needed.
  • User-Friendly Interface: The 4.3” color display combined with external IP54 cabinet pushbuttons for start/stop/equalize functions makes operation straightforward even for new users.
  • Network Integration: Onboard ethernet (with internal connection) allows for integration with your facility’s network infrastructure for comprehensive power management.
Engineered for Specific Industry Applications
The HAWKER LifePlus® Xtreme has been purpose-built for critical applications where power failure is not an option. Its rugged design and advanced technology make it the ideal choice for industries that rely on uninterrupted power to maintain efficiency and productivity.
Airport Ground Support Equipment
  • Cargo Loaders
  • Pushback Tractors
  • Baggage Tugs
  • Belt Loaders
  • Service Trucks
  • Aircraft Movers
  • Air Stair Units
Agricultural Operations
  • Produce harvesting equipment
Logistics
  • Outdoor warehousing
  • Material handling in exposed environments
Technical Excellence by Design
Built with leading-edge technology and robust engineering, the HAWKER LifePlus® Xtreme is designed to maximize efficiency, adaptability, and longevity in demanding work environments. Every component is optimized to provide industry-leading performance and reliability.
  • Superior Efficiency: HF Modular technology delivers efficiency up to 94%, reducing power consumption and operational costs.
  • Flexible Power Options: Multi-voltage capabilities covering 24/36/48V and 72/80V ensure compatibility with virtually any industrial battery system.
  • Environmental Adaptability: Internal heater, fans, and filter system with easy filter change maintenance and wider temperature range tolerance keeps the system functioning in extreme conditions.
  • Global Compliance: With CE/UKCA/UL certification pending, the charger meets international safety and performance standards.
The Bottom Line: Operational Benefits That Maximize Your Investment
Investing in the right charging solution goes beyond simply keeping your equipment powered. It means arming your fleet with long-term efficiency, cost savings, and adaptability for evolving power needs.
Reduced Downtime
The reinforced IP54 enclosure keeps batteries charging regardless of environmental conditions, in turn keeping your operations moving without costly interruptions.
Lower Total Cost of Ownership
Efficient charging, reduced maintenance needs, and compatibility with multiple battery technologies optimize your power investment and long-term savings.
Operational Flexibility
From variable AC and DC cable length options to fully programmable settings, the system adapts to your specific operational requirements for seamless integration into your workflow.
Future-Proof Technology
Charging capabilities for both traditional and modern battery technologies means that your investment will remain valuable as your fleet evolves, supporting long-term growth and innovation.
Get Power You Can Count On
Keep your equipment running longer, stronger, & smarter—even in the harshest conditions. The HAWKER LifePlus® Xtreme IP54 rated charger delivers a cost-effective and rugged power solution with superior protection, fast charging, and efficient energy usage in environments where standard chargers fail. For operations that simply can’t afford to lose power, this charging system is the ultimate solution.
Power Your Future with HAWKER® Battery Chargers & Motive Power Solutions
Explore how the HAWKER LifePlus® Xtreme and other leading-edge power solutions can keep your fleet powered and productive. For more information about implementing the HAWKER LifePlus® Xtreme into your workflows, drop us a line or find a HAWKER® dealer near you.
Get in touch with Hawker Powersource, Inc.
+1 423-... Show
PO Box 808
Ooltewah, TN 37363
United States
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
