Cyberwatch Wireless Hour Meters
- 25 Nov 2010 ( #489 )
KEYTROLLER'S CYBERWATCH hour meters are available in both a CEL (cellular network) and a LAN (local area network) wireless configurations. These inexpensive devices are designed to send the vehicle's hour meter reading once per day eliminating the need for a person to hunt down a machine to obtain it's usage. Seamless data availability allows the user to easily schedule maintenance and dispatch mechanics effectively. Either CYBERWATCH device can be programmed to automatically send emails when maintenance due interval comes to within range. Maintenance due can be set by a date or hour meter reading for each vehicle.
CYBERWATCH CEL: Is a web-based device with 2 hour meter inputs (one is typically set to key on usage and the 2nd is typically set to monitor "idle" time with a switch on the accelerator pedal). There is a counter to determine number of starts, an alarm input (for low oil/high temp) and a "mechanics job done" button. When pushed, this "job done" button sends a signal to reset the maintenance due interval automatically on the website. This also adds accountability for the mechanic completion of a job. In addition, the CEL model has GPS, so the location is sent along with the hour meter information, the current and historical locations can be viewed on Google Earth 3D. For applications where there is a theft problem, the user can set a "geo-fence"; when the vehicle leaves the fenced area---an alarm message is set which can be retrieved on a Blackberry type cell phone. The CYBERWATCH CEL is used in areas with cellular coverage and in applications where range, theft and location are issues. Dealer pricing for CEL begins at $350 per device with $6 per month wireless costs.
CYBERWATCH LAN: has it's software installed on one local computer typically positioned within range of vehicles to be monitored. A base station GATEWAY is connected to the local PC's serial port and has up to 400' connection range to monitored vehicles. When more range is required one or more "repeaters" are simply plugged into a 110VAC outlet to get an additional 400' of communication range. Dealer pricing for LAN begins at $125 per device with NO monthly wireless costs.
Use of CYBERWATCH wireless hour meters is perfect for large fleet TM+R applications where dealers are responsible for maintenance of the client's machines. It also makes for a very professional sales presentation which will set your company apart from competition by providing reports with near real time usage figures on every vehicle. Dealers have more accurate and timely data for overtime billing and department usage. The devices can be installed on internal combustion or electric machines and applications include: forklifts, construction equipment, aerial lifts, cranes, pumps, generators, Demos are available for qualified dealers.
Click to view the larger image
For more information view website: www.keytroller.com or contact KEYTROLLER, LLC. 813-877-4500 or email: info@keytroller.com
Click here to visit the KEYTROLLER ShopFront
