Cascade Corporation introduces Hi Visibility Sideshifter and Hi-Visibility Fork Positioner
- 22 Jun 2007 ( #315 )
The new 65F Sideshifter features a reduced weight and provides increased net truck capacity. The new 65F sideshifter also has a 40% improvement in visibility over the 60E it replaced.
The 65F Sideshifter is specifically designed for 6,000 - 7,000 lb. (3,000 - 3,500 kg.) class III lift trucks. Rick Whiting, Cascade Product Manager is excited about this new design, stating "on a typical lift truck this (reduced weight) could result in retention of approximately 50 lbs (25 kg) more capacity!" Like all Cascade Sideshifters, the 65F is ready to install - no welding, drilling or tapping is required. The 65F is compatible with all OEM Load backrests.
The 65K Hi Visibility Fork Positioner, evolved from the 65F Sideshifter, is a class III, 6500 lb. (3,000 kg.) capacity sideshifting Fork Positioner. This high visibility Fork Positioner allows the driver to accurately position forks for handling a variety of pallet configurations, all without leaving his seat. The 65K is easy to install, has excellent lost load and has been proven in a variety of challenging applications.
Options include a Radio Frequency Hydraulic Control (RFHC) which eliminates the need for additional hydraulic hoses or cables, reduces installation time and saves you money. The RFHC permits the use of a single function auxiliary valve to control both hydraulic functions.
To find out more about all of Cascade Corporation's F-Series Sideshifters and K-Series Fork Positioners, visit www.cascorp.com or contact your local Cascade sales representative.
Cascade Corporation
Portland, Oregon
1-800-CASCADE
www.cascorp.com
Click here to visit the Cascade ShopFront
