Introducing the Maxlion X-series 3.5-5T Side Loader
- 13 Nov 2025 ( #1256 )
Precision Handling for Long Loads in Confined Spaces
Developed by Maxlion with strong expertise in material handling, the X-Series side loader is designed specifically for long and heavy goods in narrow aisles. With a reinforced chassis, stable powertrain and operator-focused ergonomics, it delivers reliable performance in timber yards, metal processing facilities and manufacturing sites.
Use Case: Long-material handling in tight aisles — woodworking, steel tubes, panel warehouses.
Customizable to Your Application
Customized options are available to suit different working conditions, such as:
  • Wide fork positioner.
  • Wide side-shift.
  • External fork carriage with four forks — available in various widths upon request.
Main Features:
Reliable Power & Efficiency
  • Japan-brand Yanmar engine/Kubota-brand engine.
  • Delivers stable torque output, long-term durability and lower fuel consumption.
3-wheel hydrostatic drive
  • Electronically controlled variable pump enables smooth lateral deceleration, excellent maneuverability and precise inching.
  • Ensures safe operation in constrained spaces.
Ergonomics & Visibility
  • Redesigned fully-enclosed cabin
    • Improved visibility, reduced noise/heat, and upgraded interface for safer, more comfortable long-shift operation.
  • LED working lights
    • Enhanced forward and side illumination for safer loading in low-light indoor/outdoor environments.
Structural Strength & Durability
Krupp steel mast
  • High rigidity and stability for secure lifting under demanding load conditions.
Reliable mechanical valve system
  • Simplified, durable and easy to maintain — ensuring consistent and precise hydraulic control.
Easy Serviceability
Accessible maintenance side compartment
  • Side access significantly reduces service time and simplifies routine inspections.
Engine temperature meter
  • Provides direct real-time temperature monitoring to protect components and extend service life.
Contact us to find out more
⇒ Website: www.maxlion.net
⇒ Follow us:
Get in touch with Hangzhou Maxlion Machinery Equipment Co., Ltd
+86 571... Show
Office: Room 1408, East Building, Zancheng Center, No.9 Feiyunjiang Road, Shangcheng District, Hangzhou, Zhejiang Province, China
Factory: No. 2 Baisha Road, High-Tech Zone, Haining, Zhejiang Province, China
