ZAPI FZ2009B Handset Digital Console Programmer For ZAPI Dualac2 FZ5092B-CW
Hi Everyone,
This is to ask if someone knows about if there is possible that besides the software version loaded into the crown truck vehicle, I can programming the driver motor controller FZ5092B-CW using only the handset: ZAPI FZ2009B Handset Digital Console Programmer For ZAPI and the driver controller will work fine
I am not sure that if the software version loaded in the vehicle is higher than the software version loaded in the driver controller it will work just need to make changes needed for specific parameters
if somebody knows something about it let it know
Luis
  • Posted 29 Jul 2021 02:39
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
lvelasco@insercomm.com
Hi,
What I am trying to ask and know, is if I may change an access 3 Dualac2 without move anything in the logic board (software version) i.e. driver/controller got fixed on the power section, my question is if the driver/controller will work considering it has the same software released version than the one installed in the truck, just made changes in the performance parameters; i.e. acceleration %, speed, etc. Parameters which can be adjusted by the handheld. I just wonder if it could be possible trying to make an analogy with telecom equipment, where if I install a board with a software version equal o below the one is currently installed in the rest of the boards it works and, there is just need to make a specific performance changes
Just asking...
  • Posted 30 Jul 2021 14:54
  • By luis_v
  • Mexico
Did you replace the access 3? It is a dual AC traction controller. If so, you must do a software download to the truck and then recalibrate it. No way around it.
  • Posted 30 Jul 2021 12:12
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
I'm having trouble understanding. Are you asking if that ZAPI handset will work with an RC5500?
  • Posted 29 Jul 2021 03:18
  • By Triggs
Nagano NUL120-6
Toyota 02-8FD30
