yale NRO35AENS24TE095 C815 drive control fault
Intermitten problem that never occurs when I'm there. Operator sometimes gets hesitation and or jerking when applying forward or reverse. Sometimes gets message display "Drive control error" when problem happens. I'm thinking its the control handle and other suggestions? thank you
  • Posted 12 Jul 2019 17:26
  • Discussion started by 7777
Never mind to my previous question, I saw your answer about the handset, thanks
  • Posted 19 May 2022 23:50
  • Reply by Justin_Voit
Brewski, how would you check the fault history. I have several of the same forklifts doing the same thing intermittently. As soon as it gets shut off and then back on it goes away completely for an extended period of time. The box/screen only has the hour button and the speed button?
  • Posted 19 May 2022 23:48
i agree, intermittant problems are hard to diagnose, especially if they do not appear when you look at it.
What brewski suggests is one way to check, viewing the fault history would help narrow it down.
One other way IF you can get it to fault while you are testing it out is watch the drive controller LED and see if it is flashing a code.
The LED code scheme is as follows:
LED code Explanation
OFF (no flashes) No power or defective controller
ON (continuously) Controller or microprocessor fault
0,1 Controller operational, no faults
1,2 Hardware failsafe fault
1,3 M-, current sensor, or motor fault
2,1 Throttle fault
2,2 Static return to off (SRO) fault
2,3 High pedal disable (HPD) fault
3,1 Contactor driver overcurrent
3,2 Welded contactor
3,4 Missing contactor, or traction contactor did not close
4,1 Low battery voltage
4,2 Over voltage
4,3 Thermal cutback; over/undertemperature
  • Posted 15 Jul 2019 22:23
  • Reply by swoop223
thank you Brewski, i see about the handset
  • Posted 13 Jul 2019 03:45
  • Reply by 7777
You can also use the Curtis handset 1307. This will allow you to view fault history.
  • Posted 12 Jul 2019 22:26
  • Reply by BREWSKI
Do you have diagnostic software? These problems are tough if it does not occur when you are there.
  • Posted 12 Jul 2019 22:21
  • Reply by BREWSKI
Hangcha FLDCXT160
Toyota 8FGCU25
Flesherton, Ontario, Canada
edition #1235 - 19 June 2025
