yale NDR045EB Code error DTC XX107
Good day technicians
I have a problem with a forklift YALE presents me with the error code 107 is quite constant, it does not let me operate the equipment correctly.
I restart it with power off and on, but within minutes the code appears and performs the revision of safe connectors in each controller.
They have some idea of this code.
regards
  • Posted 25 Jul 2018 02:35
  • By henry_leiva
  • joined 9 Jun'16 - 8 messages
  • san salvador, El Salvador
That is a Can I/O module fault. The I/O module is mounted on the attachment on the back side of the carriage. You probably have some damaged wires. these wires run through the attachment over the mast and back to the master controller. Check the over the mast harness for damage.
  • Posted 27 Jul 2018 07:14
  • By BREWSKI
Toyota 8FBE20U
Flesherton, Ontario, Canada
Toyota 8HBE30
Load Lifter LABORER-SERIES6.000LB
Toyota 8FBE20U
Bolzoni SpA (Group HQ)
