YALE MR16 Reach Truck needs Blue Light fitting C849
I need to wire in a blue light to work when travelling in reverse. The truck has got a reverse sounder that operate when the pedal is pressed. The direction switch is just a momentary switch. Has anyone any ideas or can anyone recommend were to wire in the blue light.
  • Posted 29 Oct 2013 21:41
  • By Leon_W
  • Tyne & Wear, United Kingdom
Leon W,
Is this light you want to fit a flash beacon, if so Then Yale specifye a dedicated connection.
There are some dedicated aux fuses located forward of the deadman line contractor check to see if one of these becomes live when accelerator pedal pressed, I certainly would not connect up any other way on this truck as I'm sure Yale specify a dedicate connection infact I would not connect any aux unless you know the correct connections to make.
Regards Titus
  • Posted 30 Oct 2013 03:34
  • Modified 30 Oct 2013 20:38 by poster
  • By Titus
  • joined 6 Jul'10 - 185 messages
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Highland, IL, United States
Tacoma, WA, United States
Orlando area, United States
Dallas, TX or Lexington, KY, United States
Terberg YT223
JLG 600AJ
JLG 600AJ 2012
Flesherton, Ontario, Canada
Terberg YT223
JLG 600AJ
JLG 600AJ 2012
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Board member, UKMHA
