yale mp20x
any info available on yale mp20x ac 2005
ser c843x1724c have intermittant eps fault
torque sensor thanks guys
  • Posted 16 Nov 2012 19:27
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
i gather you have to use switch above fuses but how do you set up steering positions please
  • Posted 23 Nov 2012 06:38
  • By trevb
Give the wire's into the torque sensor connection plug a tug. Had same problem with a truck a few years ago. Think it was one of the outer wires insulation was fine but inner conductor was breaking up.wiring tested ok with a ohm meter
  • Posted 21 Nov 2012 06:35
  • By kevin_k
fault is very intermittant can get the same code by unplugging sensor wire that goes into tiller head , so probably need to change , any info or manual would be great help thanks
  • Posted 17 Nov 2012 08:29
  • By trevb
Do you need to know how to fit a new one,
Regards Titus
  • Posted 17 Nov 2012 00:16
  • By Titus
  • joined 6 Jul'10 - 185 messages
Zhejiang UN Forklift Co., Ltd
Muncie, IN, United States
