Yale GLP060 starts, runs for a while then quits, wait 10 minutes restarts.... repeat
I'm not familiar with this series lift truck.
I've checked the fuel supply, appears to have plenty of flow, no obstructions.
all engine fluids are at operating range.
coolant system working properly.
no freezing of regulator.
lift truck does not throw any codes either.
electrical system charging fine, battery fine.
valves set properly, check lash per customer request.
any help or ideas would be greatly appreciated. i'm not familiar with the newer models with the electrical systems on the regulators. especially since no codes are given.
  • Posted 15 Jul 2016 11:23
  • By OnsiteRepair
  • joined 15 Jul'16 - 4 messages
  • Michigan, United States
good
glad you found it
those do have a tendency to go bad once in a while and was going to be one of my next suggestions to check.
you beat me to it ;o)
  • Posted 18 Jul 2016 02:09
The fuel shut off solenoid tested faulty.
heat and electric coils don't mix. drops just enough voltage to shut off fuel, won't restart until it cools enough to pull plunger to allow fuel to flow.
Have part ordered.
  • Posted 16 Jul 2016 12:03
  • By OnsiteRepair
may be a bad distributor module
or possibly the 5A circuit breaker in the ignition system is faulty
does the MIL light come on at all when it fails?
it can come on even without showing a code but it generally is accompanied by a code / flash
  • Posted 16 Jul 2016 10:02
MODEL: GLP060TGNUAE087
TYPE: LP
SERIAL: A87B11028X
WEIGHT: 10323
  • Posted 15 Jul 2016 23:44
  • By OnsiteRepair
can you post a full model and serial number?
that would help us determine what systems this truck has so we can help you better figure this out.
  • Posted 15 Jul 2016 21:58
Thank you guys in advance. I'm new posting here, been perusing older posts for a few days
  • Posted 15 Jul 2016 11:24
  • By OnsiteRepair
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
Toyota 02-2TD20
Nagano NUL120-6
