yale glc080vx gm engine
truck star runs 20-30min shut off. waiting 15min. star run only 20-30min again,
any techs can help pls.
  • Posted 22 Aug 2020 03:35
  • Discussion started by hellokitty
echo3618@hotmail.com
thx fishmech
  • Posted 22 Aug 2020 03:49
  • Reply by hellokitty
Look for connector under floor board on left side of truck. Put in jumper from A to D and turn switch on. Watch engine light blink. There should be three consecutive codes of 112, then any engine codes should come up. A couple of things you can also check. Make sure alternator is operating correctly. Should be charging about 14.2 to 14.5 volts. Make sure radiator is full. Look at oil pressure sender under the distributor. Any oil leaking may be signs of the sensor failing. When pressure drops to low, engine will shut down.
  • Posted 22 Aug 2020 03:42
  • Reply by Fishmech
  • Virginia, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
Wentzville, MO, United States
