i have a yale forklift when you turn it on the screen flash with a wrench and a error code 12810
Tenfold problems con el codigo 2546. Mepueden ayudar
Please use English language.
Littoral Translation
I have problems with code 2546. Can you help me?
The plug was disconnected. Operator forgot he had disabled it last week to prevent weekend use. Thank you!
accelerator pedal position out of range low.
Check the connector at the pedal assembly.
I have the same problem. It's a Yale Model ERP040VTN48TE094, Serial G807N06641M.
there are many yale models
which one do you have and what is serial number?
would make things a bit easier to find ;o)
