Yale ERP030TH error codes
Hi,
I have a Yale ERP030TH that has more than one problem and a bunch of error codes.
I have repaired everything that has to do with the drive motor section and am having problems with getting the hydraulics to operate.
There are no errors coming up on the display when trying to use the hydraulics but, I have a bunch of stored codes and need to know what they are.
Does any one have the codes for this truck?
List of codes: 2, 8, 12, 52L, 238, 209, 90R, 43L, 7, 43R, 209R, 245, 210.
  • Posted 15 Feb 2013 04:07
  • Modified 15 Feb 2013 04:16 by poster
  • By gfugate1
  • joined 11 Mar'12 - 4 messages
  • Washington, United States
good job...
yes sometimes its the simple things that get ya ;o)
  • Posted 16 Feb 2013 22:56
Fixed it!
Found a loose cable at the controller.
I find it amazing that you can get so many codes from a loose wire...LOL
Thanks for your help :)
  • Posted 16 Feb 2013 04:58
  • By gfugate1
The serial # of the truck is:
F807N01532B
  • Posted 16 Feb 2013 02:13
  • By gfugate1
The battery is new and charged with no bad cell's.
Checked all of the wiring under the battery, motors and control panel.
The truck is dry also.
I will post a serial number when I get to work in a few hours.
There is one thing here that is strange and that is that the battery indicator on the dash never goes to full, it is a few bars down from full. When the key is turned on all bars on the dash come on, so I know they are not burned out.
The battery voltage is set correctly.
By the way, this truck has a AC2 Zapi controller for the drive and pump. Pump motor is DC as it has brushes.
  • Posted 16 Feb 2013 00:39
  • Modified 16 Feb 2013 00:41 by poster
  • By gfugate1
first things first
serial number please?
secondly, is the battery charged fully? what state (condition) is the battery in? make sure its charged fully and all cells are in good condition.
Run a load test and check each cell and make sure you donot have any failing cells. Faulty cells can cause low voltage under a load and can cause random codes being triggered.
Check the cable tray where the cables go under the battery to the rear of the truck to the control panel. Any corrosion? Cables eaten up from acid corrosion?
Too many codes showing up
has this truck gotten wet (from rain or some other source such as pressure washing?)
  • Posted 15 Feb 2013 22:00
Deborah Baker Deborah Baker
Crown RD572513TT6860R
JLG G12-55A
Bolzoni SpA (Group HQ)
