I checked the other possibilities as you stated Justin. Same "actuator" since machine was new 4 years ago. Started this problem after the dash display was replaced, which is why I suspected wrong parameters. I think these units have an issue with the displays not lasting? I see Flight Systems has an exchange program on these.
Thanks again.
Thanks guys. The dealer came thru with the proper parameters. Function #8 was way out on the SP/SR controller which set the field current. Now everything works like new. Turns out someone had inadvertantly adjusted the parameters wrong and didn't double check them. Customer was ready to trade in his Yale as he could only use it for 2 hours. Good thing he had a cooler to park it in for a half hour a couple times a day.
Isn't an equalize charge a HIGH rate of charging to bring all the cell gravities up to the same? I have heard of both varients so which one is the truth? Also what is the difference between the GE SP/SR and the SX controllers if any?
Buddy
you have to rule out the "steering wheel actuator" in cases like this
Dang I like that
equalize is a slow charge (about 36 hours i believe) if he uses it everyday its probably not fully charged running the equalize every other day
running the battery with a crap charge can heat components
have him change his charging habits
equalize should be run once a month on a light duty shift
batteries should be used for a single 8 hour shift then charged 8 hours then allowed to cool an additional 8 hours
if he is running multiple shifts on a single charge or charging it several times a day (lunch breaks etc) that could cause this
also pushing (bulldozing) pallets along the ground can overheat the machine
lol
Hello,
I think I have the adjustments you need.
Send me a mail with the volt's off the battery.
[email address removed]
Cheers
