yale electric pallet mpb040-24
batteries not charging from on board charger, charger output showing 32 volts at cable ends going to battery when disconnected from batteries,will not lift when voltage low
  • Posted 7 Nov 2008 11:43
  • By rick_o
  • joined 7 Nov'08 - 33 messages
found poor connection inside charger bat positive output
thanks everyone for the input
  • Posted 8 Nov 2008 08:29
  • By rick_o
and Rick, you need to test with a load on the batteries, as well as "at rest".
you may have a bad connection at the battery cables...
  • Posted 7 Nov 2008 21:20
my friend the electrical forklifts don"t have ground, the positive
and negative is insolated from the frame, wheol if you have a
multimeter , you can test the voltage in the outers cables from the charger. you can see battery voltage.
  • Posted 7 Nov 2008 13:09
  • By josefina_p
  • joined 15 May'08 - 7 messages
  • chihuahua, Mexico
ruben sierra
batteries 2 weaks old , water level ok seams to not be charging ,what is best way to test on board charger, check posative to chassis groung?
  • Posted 7 Nov 2008 11:59
  • By rick_o
My friend , I think you have some, cells less water o bad cells.
  • Posted 7 Nov 2008 11:49
  • By josefina_p
  • chihuahua, Mexico
ruben sierra
Maxlion FB25EH
Toyota 02-8FD30
